Roof Skin Removal
  • Dobby84
    • Feb 2011
    • 1169
    Roof Skin Removal
    I've read through a few posts but would love to know if there is any sort of 'how to' guide to remove the roof skin off an S2 coupe?
    Mine is damaged and beyond repair.
  • Jaswan
    • Apr 2011
    • 771
    You mean the steel roof of the body?
    • Dobby84
      • Feb 2011
      • 1169
      Yes.
      • Dobby84
        • Feb 2011
        • 1169
        Seen a few threads on motorgeek but nothing detailed
        • Jaswan
          • Apr 2011
          • 771
          I can't really help if the intent is to replace it with another steel panel and want a factory finish.
          But, for mine I think I cut it down both sides on the insides of the rain groove. I roughly cut the r
          Front and rear close to the windscreen and hatch to remove the bulk of it. Then drilled out the spot welds to remove the remaining pieces.
          I am going to glue in a new panel that will start/stop inside the V of the rain groove.
          Regards.
          Jase.
          • Jaswan
            • Apr 2011
            • 771
            Screenshot_2024-07-30-20-19-47-012_com.miui.gallery.jpg this was work in progress but you get the idea.
            • Dobby84
              • Feb 2011
              • 1169
              Bet that made welding that beast of a cage in easier. Would love something like that.... Mine is damaged where the roof rolls over into the C Piller.
              I see there are lots of spot welds so assume drilling them out and split any glue and it 'should' come off....
              • Jaswan
                • Apr 2011
                • 771
                Is there no possibility of just welding in a section to replace the damaged part instead of removing the full skin?
                • Dobby84
                  • Feb 2011
                  • 1169
                  Probably but have the usual rust along the windscreen
                  • Dobby84
                    • Feb 2011
                    • 1169
                    Well I had a very productive weekend.
                    S2 roof skin removed.
                    Donor car interior stripped, windscreen out and roof skin removed.
                    Still need to clean up, pres and start plug welding all the drilled out spot welds but skin layed in position for now.
                    Might look to swap the rear quarters too as the donor car is spotless where as my S2 quarters were rusty and I have patched them..... More drilling I guess.
                      • Dec 2017
                      • 5992
                      Nice work
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        Amazing job, why do we torture ourselves over these cars
                          Excellent work!
                          • david1980
                            • May 2014
                            • 1025
                            What was the reg of the donor vehicle?
                            • Dobby84
                              • Feb 2011
                              • 1169
                              Originally posted by david1980
                              what was the reg of the donor vehicle?
                              m723rcw
