Currently have a very soggy drivers side foot well
I've blown compressed air through the front two sunroof drain holes and also the scuttle panel ones.
I searched on here but can't find an answer to the following:
Are there rear sunroof darin holes????
And if so, how do I get to them???
Oh, its an avant if that helps.
not sure where its coming from, have you checked your bonnet release cable where it goes through the grommet near the fuse box?
Don't think its that though as the drains should deal with any leaks there.
and try it as water in the footwell is the usual sign of a blockage
