Ellipsoid Headlight
  • smudge72
    • Apr 2005
    • 53
    Ellipsoid Headlight
    I need some help please.
    I have a driverside ellipsoid headlight but it has some broken brackets on it & i need to replace it for the mot as it doesn't sit right.
    So my question is can i the back of the headlight with a coupe one?
  • chezz
    • Apr 2007
    • 440
    Is it totally beyond repair? Can you not repair the broken pieces by using the solvent/cement that is used to join drainpipes etc. when this stuff sets nothing will shift it... the repair should be just as strong as the original.
    • Acidburn
      • 13459
      agree with chezz, also if its the top bits that are broken then make up some small metal bits to fit there instead, you could make 2x z bits to hold it together. Cheaper than buying a new headlight but if it comes to that then i'm sure anton on here would buy your old one
      • smudge72
        • Apr 2005
        • 53
        Cheers for that i will give it ago by using solvent cement. I did triy with araldite but it was crap & snapped staight away.
        but still does anyone know if the coupe moulding fits cos i can get one for silly money
        • terrybullwon
          • Mar 2006
          • 8782
          As long as its a ellpsoid casing it will be fine. I used plastic cerment on mine for a year with out a problem.
          Chef
          • epic
            • 1317
            The top clips are broken on both of mine and have been since I bought the car more than 10 years ago. I used a door stop cut in half and long course threaded screws to anchor the lights. Never had a problem with them in all that time,
            • gavs20v
              • Sep 2004
              • 3057
              answering your question- yes they are the same as coupe ones
              S2 Cabriolet.........
              • anton
                • Jan 2005
                • 802
                i'd be on it like stains on a matress! i'm sure the clips are all the same though.
                Ant
                91' Coupe quattro 20v - project
                KW V2s and other goodies
                now gone
                03' BMW 330CI - Sold
                08' A5 Coupe 3.0l tdi quattro - Sold
                57' BMW 525d M Sport Touring
                • Acidburn
                  • 13459
                  Ant
                  nice wording
                  btw i got the brakes so there for sale from......................................now
                    Mine are held in with long self tappers straight into the casings
                    • Ryan80
                      • Jan 2008
                      • 154
                      • Home: Northern Ireland Current: United Kingdom
                      yes it is very easily done. I did the same job on a broken one i bought off here, straight swap with the coupe parts
                      next step for me is an hid upgrade! lol
                      Time waits for no man. Unless that man is Chuck Norris.
