Got the S2 MOT sorted yesterday, was having a poke around the underside with my MOT man and I noticed that my front jacking points are i bit mangled from my trolley jack not interfacing with them properly. There is some light surface corrosion and some flacking under-seal in this area, nothing serious but as where all corrosion is concerned the sooner sorted the better.
So the Plan :mischeif:
Friday I will remove plastic sill covers (any tips for doing this?)
I'm booked into use a ramp for 4 hours on Saturday Morning. This is where the jack points will be repaired and the rust mechanically removed.
I will then apply various products from Bilt & Hamber at home over the rest of the weekend and refit the plastic sills late on Sunday
Finally I am going to make a device that fits on the top of my trolley jack that connects with the sill properly, all ideas welcome
Ill take some shots of my progress.
Rich
Rich
