Jack point damage
  • rj scotty
    • May 2006
    • 2195
    Jack point damage
    Got the S2 MOT sorted yesterday, was having a poke around the underside with my MOT man and I noticed that my front jacking points are i bit mangled from my trolley jack not interfacing with them properly. There is some light surface corrosion and some flacking under-seal in this area, nothing serious but as where all corrosion is concerned the sooner sorted the better.
    So the Plan :mischeif:
    Friday I will remove plastic sill covers (any tips for doing this?)
    I'm booked into use a ramp for 4 hours on Saturday Morning. This is where the jack points will be repaired and the rust mechanically removed.
    I will then apply various products from Bilt & Hamber at home over the rest of the weekend and refit the plastic sills late on Sunday
    Finally I am going to make a device that fits on the top of my trolley jack that connects with the sill properly, all ideas welcome
    Ill take some shots of my progress.
    Rich
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
  • Big Lee M
    • 2571
    Guy on detailing world sells modified hockey pucks for the trolly jack, there a good idea and cheap.
    Just some finishing touches to do now
    • rj scotty
      • May 2006
      • 2195
      I assume these have a groove cut into them ?
      You got a link ?
      cheers
      • andy10v
        • 5996
        Buy a hockey puck and attack it with an angle grinder?
        Sold ABY-stock
        • Big Lee M
          • 2571
          Here you go buddy hope it helps, keep meaning to get one.
          Group buy suspended for the time being - see post 313 (page 32) and resister your interest if you would like one once I make another batch Edit with the following three 'production quality' pics: - I had the problem finding a suitable spot for a trolley jack and a second spot to lower...
          • benntenn67
            • Jun 2009
            • 859
            yep ice hockey puck £3,50 on ebay & then cut a groove - man
            http://cgi.ebay.co.uk/STREET-HOCKEY-...item1e60e40a77
            Audi S2 Coupe 1995
            VW Passat GL5 (hatch) 1986
            Carrera Subway 8
            • rs2315
              • Jun 2006
              • 867
              Everybody should check this.
              Looked at mine a couple of years ago. Thought it would be a short job, but you find more rust the more underseal you scrape away.
              If left holes in floorpan for sure.
              Crappy job scraping underseal off with car on stands.
              Do it if you love your Audi.
              rs2315.
