Fingers, toes and testicles crossed...
  • Rusty
    • 18953
    I might have a dry coupe...
  • s2driveruk
    • 12696
    good luck.....on a dry coupe and uncrossing those balls
    1992 3b S2 Coupe
      Good day to test it, proper thunder storms here! Good luck!
      • DJones
        • Jun 2005
        • 2020
        Hope it's sorted! A friend of mine twisted his testicals playing with his dog (don't ask) anyway years later wife left him, he's a Jaffa! Well one live one in about 20 gallons of the stuff!
        Un cross em...
        • Christophski
          • 3632
          I would see a Dr mate, I hear it can have damaging consequences as above suggests! hehehe Also hurts a fair bit apparantly!
          • Rusty
            • 18953
            Emergency surgery in 1998 sorted it out (yes, really )
            • Christophski
              • 3632
              Ouch and the same thing happened to a mate when I was at school. He dropped like a stone, grabbed his family jewels and went purple in the face very quickly. On this occasion the matron didnt offer a freezing bag but did suggest hospital asap!
              • Ian Simmonds
                • Jun 2005
                • 2858
                Un cross em...
                That has to be 'post of the day' right there....
                93 MTMS2 Avant
                • Rusty
                  • 18953
                  Still dry in the footwells, just got a small leak on the other light cluster in the boot to cure now...
                  • John.
                    • 2615
                    What have you done at the front/bulkhead, interested as I have footwell issues.
                    John.
                    • Rusty
                      • 18953
                      Pull the door seal away from A pillar and roof.
                      Remove tape covering holes.
                      Drill out all rivets back to near B pillar.
                      Remove side trims by pushing down windscreen until free.
                      Clean.
                      Refit windscreen trims with sealant and new rivets.
                      Apply sealant to roofline trim.
                      Use rivets to attach to roof then down A pillar.
                      Use tape to seal holes.
                      Use a little lubricant to help get door seal back in place - work from B pillar forwards.
                      Done.
                      • Rusty
                        • 18953
                        Cheers to Newsh for telling me to get it done
                        • John.
                          • 2615
                          Not a 5 minute job then.
                            Cheers Andy! Not a quick job but its a great feeling having a dry coupe!
                            @John, I had other problems too, check this thread http://www.s2forum.com/forum/showthr...ht=water+leaks
                            and the sticky thread in the body section http://www.s2forum.com/forum/showthread.php?t=55406
                            And http://www.s2forum.com/forum/showthread.php?t=47518
                            • Rusty
                              • 18953
                              Allow about 3 hours or 2 if you've done some exploratory work beforehand, like taking off the door trim and had a good look about. I think I spent about 4 hours taking a look, so was comfortable with it.
                              Mine had water running down between the trim and body. This was getting it at the top of the a pillar where the sealing tape had been destroyed by the muppet that fitted the windscreen
