anyone got any good tips to stop it happening?
squeeking window rubber
I have tried some of that stuff the BM boys swear by for all treatment of rubbers.
Gummi Pfledge or something like that
Cleans, conditions and makes them look like new !
No complaints here
For what this cost me so far I could have bought an S2
sounds like a good bet,ta
I had this and it went away after I removed and cleaned the regulator - the slider bushes were absolutely gunked up and the wheels were in real need of some lubricant too! I also removed all the gunk off the part that runs along the top of the door and took it back to the suede feel rather than a crusty mess. Took an age the first time but I'd say you'd manage it in an hour as you'll not have to work out how it all comes to pieces!Cheers'en, AndyC
Window squeek
I had drivers window making a horrible noise when going up/down I took the door card off cleaned and greased the wheels etc in there, it made a huge difference the window now glides up n down. I too thought it was the rubber causing the squeek/noise.
Good luck fixing it. Condor.
:wave: :thumbs:Comment
I agree,I had drivers window making a horrible noise when going up/down I took the door card off cleaned and greased the wheels etc in there, it made a huge difference the window now glides up n down. I too thought it was the rubber causing the squeek/noise.
Mine was the same. Door card off, clean up, re-grease, now is silky smooth.....
ChrisHonda CBR 1100XX Blackbird Turbo....undergoing major changes.....
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
