aaaaaaaaaaaaaaaarrgh!!!
I've been trying to get my driver's side window to sit properly and seal properly since the summer and it's doing my head in. I had to remove the regulator to clean and rebuild it and then it started...
Over the weekend, I tried to adjust it a bit more, then the motor gave up the ghost, so I had to replace the motor and try again. It wasn't ideal but a little bit of fiddling this morning lead to one of the cables popping off this morning, just when it was nice and cold and windy outside with spots of rain that started just as it all went wrong... I've spent a few hours today rebuilding it again and getting it working...ish. Put it all back together, put the window up and it must have moved a bit, as it's tight at the front
More to do then.Then I've got to sort the passenger side, as that's started with the wind noise after I re-hung the passenger side door.
Suffice it to say, I'm properly annoyed with it today
