RS2 Mirrors
  • Technogym
    • Dec 2004
    • 200
    • Country: Norway
    RS2 Mirrors
    HI there! Want to start a discussion on replacing the rear wiew mirrors with the RS2 ones.
    Is it a bolt on operation?
    Is there any option to buy two equal size mirrors for the looks?
    Where's the best price?
    Are there any other alternatives, such as mirrors with built in directional light?
    Regards Vegard M
    Do a search on the forum. Doug and others have done it. Its NOT a straight bolt on as a little metalwork is required on the doors and some electrical changes are needed IIRC to the connector...
    Those mirrors actually come from a Porker of some sort - maybe easier to source from a Porsche breaker.
    • GandalfS6
      • 332
      • Country: South Africa
      The Audi RS2 mirrors do not need any electrical changes but I am not sure if that is the case with the Porsche 993 mirrors.
      1995 Silver S2 (ADU) Coupe
      2006 Porsche 997 Carrera S
      2006 Misano Red RS4
      2004 VW Touareg V8
      2007 Golf Mk1 Race Car
      2004 Mercedes Benz Vito 112CD
      • Jonas_R
        • 3780
        • Country: Denmark
        Paul, if you by the RS2 mirrors from Audi they are a straight fit on the Audi 80 Coupe, so the should fit straight on the S2 Coupe.
        He bought them from germany for a little under 200£ including VAT and shipping.
        If anybody is interested iam getting some parts from my german dealer here next weekend can ask what the price is and so on. I get a 10% discount.
        /Jonas R.
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
          Ahhhhhhhh - didn't know that... So the door surgery, and wiring change, is only required for mirrors sourced from a 993 then . Good info - thanks !
          Paul
          • Doug_RS2
            • 3847
            The audi RS2 mirrors need some electrical splicing to the S2 door loom. You can get the RS2 loom so it would be a straight swap, but it is expensive. There was an electrical diagram for the RS2 mirrors - somewhere - but this was not correct for the RS2 mirrors you can buy from Audi - maybe the design has changed from 1995.
            RS2 has a special bracket required to bolt to original S2 mounts in the door
            The hole for the base of the RS2 mirrors, on the S2, needs opened out - easy with a dremel style tool.
            • Jonas_R
              • 3780
              • Country: Denmark
              Dont quite get this, cuz as i said my friend bought the RS2 mirrors from audi in Germany and they where a straight fit on his Audi 80 Coupe, and i dont think there is a difference between audi 80 coupe / s2 coupe.
              However not sure about the electrical part, can ask him about that.
              /Jonas R.
              • Technogym
                • Dec 2004
                • 200
                • Country: Norway
                Good info guys!!
                So bottom line is that if You buy the RS2 mirrors from Audi or VAG parts, You need the bracket as well, and then it will be a easy fit. I can see there are different thoughts about the electrical loom, i dont see that as a problem, got the knowledge to trace and find out the connection myself, will of course take some pics and post it here!
                But has anyone tried to mount some other mirrors such as M3 or other products?
                • Technogym
                  • Dec 2004
                  • 200
                  • Country: Norway
                  And Paul..... tried to pm You about the Samco set for the 3B! But havent heard anything from You!.....
                  • Doug_RS2
                    • 3847
                    I am 100% sure you have to cut the hole in the door to get it to fit.
                    I got the kit of parts (including brackets) from vagparts.
                    • RIX
                      • Jul 2004
                      • 229
                      • Country: Denmark
                      there is a german guy,he´s put audi tt on,plus made a very nice armrest and load´s of other thing´s on his audi 80 cab,he has a site but i have lost it,htere is even a step by step.
                      Regards
                      RIX
                      • desmo888
                        • Oct 2003
                        • 390
                        Martyn, where are you? I need those brakets!!!
                        Dave K.
                        USA
                        1991 e//S2 (home built S2 - the only way to get one in USA!)
                        2001 S4
