Thank You newsh , are you talking about part number 23 ?
Sunroof Seal
Originally posted by sailaz View PostThank You newsh , are you talking about part number 23 ?
Ordered as well from https://shops.audi.com/de_DE/web/tra...term=895877297
hopefully will stop leak ....
Originally posted by newsh View Post
Make sure your drip tray is in place, under the back edge of the sunroof panel when it’s closed. You should be able to see it when the roof is tilted up. If it’s not there it is probably stuck down the back of the cassette and you can fish it out and clip it back in place.
Good.
Now I discovered another way these sunroofs leak. The surrounding inner part is sealed with a special non hardening sealant. If it's disturbed in any way, water will come in around the top of the a pillar. I ended up removing mine and found some rust underneath. I cleaned it all up, painted and 're sealed. So far it's been leak free. I used tiger seal.Nothelle S2 Avant
These stainless runners also need to come off and get sealed. You need to be careful that you don’t get any in the cord track which is greased. I used silicone grease in the track.
I put some neoprene tape under the outer cover. Take it all apart and it’s all pretty self explanatory.
More pics in my thread I think. Check my Nothelle N300 Re build thread.
Sent from my iPhone using TapatalkNothelle S2 Avant
- 1 like
