Hello i have a bit of a problem in my hands i bought very cheap headlight whit good class but whit 2 bottom clips only and its for my B4 model Coupe and i have this good in all other except glass headlight how hard is it to change the glass from the good one to the broken glass one ?
Changing the glass on headlights
Tags: None
It's really easy, pop the little metal clips off with a flat screwdriver under the end with the small hole, lift off the glass and rubber, clean the rubber and glass and refit. Don't touch the silver reflectors inside at all, and don't try to clean them except with clean air. -
Great thank you so much for the help i tought it was hard but sounds pretty simple again thank you
it worked great it was really easy to remove but now i just wonder what kind of glue i need to that rubber part it had some glue on it dont know if thats from stock ?Comment
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
