Headlight trims
  • AndyP
    • 6049
    Headlight trims
    Inspiration for this one came from Vas who has modified the std. trims to include an air inlet. I thought I'd make some from scratch and add an even bigger inlet.
    They are not finished yet, I still need to do a bit of work on the fit and finish, then paint them to match the car.
    Pretty pleased with them so far. I might even make them again, this time using mild steel as stainless is a bitch to bend. I think I could go even wider and get rid of the gap between the trim and bumper which has always bugged me. This way I can make the air inlet even bigger.
  • A80Avant
    • 10873
    • Country: Greece
    Andy, why dont i lend you the RS2 trims and you can make them from steel as well. That mesh looks really good.
      nice one Andy, looks excellent! did you mill out the shape & cut-out?
      Fancy making any more?
      • djh
        • Jun 2011
        • 1622
        • Home: United States Current: United Kingdom
        Nice, be interested to know if that helps, just needs the rs2 angle now as vas said.
          would be pretty difficult to get the compound angles on the RS2 ones, you'd need to press the part or machine it from billet i think.
          • K Simmonds
            • Dec 2007
            • 7632
            That's a bloody good idea, think I might make my own out of ally.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • re2500
              • May 2007
              • 2185
              Good work! thats impressive, like other have said, just need to replicate RS2 ones now.....
              "Difficult is worth doing"
              • A80Avant
                • 10873
                • Country: Greece
                fiberglass would be easier. I think i have an unmolested set back home that we could use, as mine have been molested on the right side with a similar mesh
                • re2500
                  • May 2007
                  • 2185
                  The only trouble i could see with using fibreglass is that the trim has to flex a small amount to fit it properly, fibreglass i think would be quite rigid?
                  • A80Avant
                    • 10873
                    • Country: Greece
                    i was wondering that if you get a piece of metal and weld the mounting points a bit at an angle, with a bit of grinding here and there, it could work... ?
                    • AndyP
                      • 6049
                      Is it really worth all that hassle just to get them at a bit of an angle?! I know I'm not that bothered, as Alex said, creating the compound angle would be a nightmare.
                      • A80Avant
                        • 10873
                        • Country: Greece
                        of course it is worth it! you can sell it for more than 100GBP afterwards since it is custom made of a part already NLA!
                        think of the $$$ hahaha
                        but dont go to the dragon's den with this idea though...
                          If you made a slightly boomerang shape when you bent it you'd get the front at an angle, I think..
                            The hours it takes to make custom parts to this standard, £100 is nowhere near enough!
                            I think these are is one of those things you have to make for yourself!
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              If some one can send me the RS2 ones I can have them made
                              By a friend
                              Chef
