Testing Servomotors for the A/C climate Flaps
  • Testing Servomotors for the A/C climate Flaps
    As Title....Testing Servomotors for the A/C climate Flaps, I have my Climate unit out for a recon.... and Know one of my servomotors is not fuctioning and would like to test the 3 off them but can find no wiring info on them, can anyone assist
    RS 2 580HP
    Pin1 - Motor +
    Pin2 - Motor -
    Pin3 - Fixed end potentiometer, 5V+, all connect to pin C8 on control unit.
    Pin4 - Other fixed end potentiometer, ground, all connect on pin A12 on control unit.
    Pin5 - Variable end potentiometer
    Wire colours vary, but the pinout is the same on all 4 motors.
    DM me if you want a diagram.
      I've replaced a few of mine with these:
      https://www.ebay.co.uk/itm/Dc-Motor-...cAAOSwGIRXYTan
      Also found the potentiometer needed a strip down and contacts cleaned to get it all working properly
      Not a straight forward task but easily doable with a bit of patience
      I used this as a guide, not exactly the same, as the pot doesn't come apart as easily but it's a good start
      https://www.audiforum.ca/a4-b5-b6-b7...leaning-72039/
      1989 NG Q Pick-up (Daily)
      2002 ASZ Golf (Doris' Daily)
      1997 AJK-G2 A6 Avant Q (In surgery)
      1999 AGZ Bora (Daily 2)
      1994 ABC A6 Avant (Spare)
      1984 JS Coupe GT (Slow progress)
      1982 WN Coupe GT5 (Spare)
      1983 MK1 Golf GTI Pirelli (In storage)
        Thanks for the feedback....
        RS 2 580HP
          Originally posted by Typ89 View Post
          Pin1 - Motor +
          Pin2 - Motor -
          So what would the best way to test and see which one is faulty ? I was thinking to add power to 1 & 2 would that do it ?
          RS 2 580HP
            Yes you can, but i'm not sure what voltage they're normally fed with. You might wanna but a light bulb in between before you set 12V on them.
              They are 7v.... so I will need to find a suitable supply
              RS 2 580HP
