Heater box foam sheet
  • Heater box foam sheet
    Can you get a replacement stick back foam sheet for the heater box seal flaps?
    This would be interesting to know, as since my heater matrix went and was replaced a few years ago ive had sporadic little pieces of foam fly out at me from my heater vents.
    Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
    "Difficult is worth doing"
      I would also like to know if there is something to replace the old deteriorating foam with. I've got to do something before the box goes back in.
        I would use something like this, glued on with high temperature adhesive
        http://www.automobiletrim.com/vinyl-foam.html
          Ensure a good adhesive is used, I replaced the foam inside and the damn self stick adhesive must have failed. I barely have any hot air coming through in the winter
          ABY S2 stroker (work in progress)
          B5 1.8T quattro
          B4 2.3 (decommissioned)
            There is a black insulating felt padding that is used by Mercedes Benz for insulation purposes. It has an adhesive backing. I have used it to refresh a couple of heater boxes that have lost their foam insulation for the flaps. The part # should be 000-989-23-10 or 001-989-23-10. It is about 70mm in width & comes in small rolls. If you know any of the techs at the MB dealership he probably has some in his tool box.
            HTH, Chris
            "Nulla tenaci invia est via"
              I just re-did the flaps in the S2 today.
              I used the foam backing on replacement roof lining velour. Peeled the velour off and used spray contact adhesive.
              Here are some pics on my thread http://www.s2forum.com/forum/showthr...t=56284&page=6
              B5 1.8T quattro
                I did mine using a reasonable quality felt and contact adhesive, had no problems with it and it should not break down like the foam in the future.
                1991 Audi S2 Coupe
                  A search reveals this.
                  http://www.s2forum.com/forum/showthread.php?t=35461
                    This looks about the same as that used by skull. Thoughts -
                    http://pages.ebay.com/link/?nav=item...d=200763508672
                      Looks the same that I used.
                      Works chop chop.
                      You need a sharp blade cutter to trim the new edges but the rest it's dead easy.
                      The big work (more of a pity work..) it's cleaning the old one to have a clean surface.
                      Stefano
                      http://www.audisportclub.com/
                      http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
                        Ruffiano shared this with me..http://forums.quattroworld.com/9080/msgs/22137.phtml
                        http://i1030.photobucket.com/albums/...q/IMG_0481.jpg
                        Peter S
                        1990 ErsatzS2 - track toy
                        1991 Coupe Quattro
                        1991 Coupe Quattro
                        1995 S6 Sedan
                        1995 S6 Wagon
                          i had some armaflex in my hand today and thought to myself.. what can i use this on? lol no i know i'll be grabbing some tomorrow
                            Any chance of a new link for the foam for this job?
                            Also what make of matrix are people using? I don't want a cheap one that will leak in a years time!
                            • #15
                              I used this stuff https://www.ebay.co.uk/itm/201181704646
                              I wasn't that impressed with the fitment of the Nissen matrix, given the choice go for a Valeo as that is what my original was.
                              This gallery has 2 photos.
                              91CQ20v - Gone to a new home
                              93UR-S4 - The Magic Carpet
                              94S2Bus - The Emerald Express
