S4 climate problem
  • spink
    • 4382
    S4 climate problem
    Just bought an S4(AAN), its got climate control but its only blowing cold air.The temp gauge on the dash doesnt work so was wondering if this may be linked?.Would vagcom pull codes for either of these problems?
  • quattroboy
    • 164
    • Home: United Kingdom
    Climate Control Blowing Cold
    My S6 does the same
    Send me a PM and I will tell you what could be the problem
    I will be posting the fix when I get mine sorted but it will be a "Warm Weather" job, which is why I haven't done a forum BTDT yet
    Ta
    Dave
    1997 S6 Avant
    • JasonS
      • 112
      I know that the AC compressor won't come on if the ouside temp is below a certain value, so it may well be connected.
      Mine works fine.. so I can check stuff on mine if it helps..
      1996 A6 TDI Quattro Avant, Xenon HIDs, A4 Autodipping rearview.
      Previous: UrS6 with RS2 bits.. <sigh>
      • twoqu
        • Sep 2003
        • 3103
        James,
        Two possibilities. One is the water valve. The other the temp flap.
        The water valve is tucked away behind the head. It has a vac pipe going to it. Might be worth checking to see whether it moves and/or has vac applied to it.That is the hot water supply.
        The temp flap "blends " the air through the heater matrix. You will have to take the plenum cover off to access this. This is controlled electrically I think. Looking at the flap positions, if it is angled towards the front of the vehicle it is in the cooling position, towards the back, heating. Again you might need to alternate the climate to see if anything moves.
        Other than that, there is always the possibility it is the control head!
        The control head has a quite impressive fault diagnosis using the segments in the display. Unfortunately it is a PITA to describe unless someone like SJM has stuck it on their site!
        That might be enough to get some warm air into the car.
        You could measure the outside temp sensor resistance outside(cold) and inside(warmer) to see whether it changes.
        Good Luck!
        • spink
          • 4382
          Thanks chaps.Will let you know how it goes.
          • spink
            • 4382
            The 2 codes i got were 08.5/13.7 which are the temp flap
            For future reference
              I fixed the temp flap motor on my mates 200 with CC, its a bit of a pain to get to IIRC but was just a matter of unsiezing it. A little motor with a screw thread to operate the flap, (works like a resistance bridge I think) The motor was stuck or something..
              http://www.12v.org/maintenance/index...&ch=ccodes&v=1
              • quattroboy
                • 164
                The Compressor does indeed stop working when you get a very low outside temp, my A4 Climate dosen't work below 3.0 deg C. All to do with protecting the system from failing because it is too cold to operate etc.
                However, this isn't connected to the "No Heat" coming through the various vents. The problem is with the 3 Potentiometers that control the 3 Flaps, which in turn are operated by the Climate Control Head Unit and are responsible for directing hot or cold air through the various outlets.
                Heat should still come through the vents even if the compressor isn't working.
                1997 S6 Avant
