Really high exhaust temps are usually caused by a lean condition. Is it possible you have a blocked fuel filter and or a bad fuel pump? (I had terrible fueling probs on my ur till I finally replaced filter and pump)
Check for a leak between Maf and turbo. (unmetered air being drawn in)
Check the vacuum pipe to the Fuel Pressure Regulator
IIRC Graham on this forum had the glowing turbo syndrome when he fitted an RS2 turbo without a remap.
