New Wagner Cast Exhaust Manifold
This is a sticky topic.
  • Bram
    • Aug 2006
    • 2582
    Carsten will bring his Cast manifold also with T3 in Feb. Will that do the job for you?
      Originally posted by Lupo911
      The Production Run is startet. But the first Run is nearly sold out the next Batch is coming in 1-2 Month.
      The Sq project is on hold because these is not enough demand (yet).
      Herr Wagner (Carsten): Now that you have a batch done and out there, have you had a chance to flow test the actual manifold in direct comparison to the OE RS2 manifold? I saw some preliminary flow numbers from the plastic mock-up/model a while ago but I was skeptical because of the smoothness of the plastic.
      I am hoping that you have flow numbers from the real manifold.
      Dave F.
      • fasterthenrs2
        • Nov 2007
        • 275
        • Home: Latvia Current: United States
        #183
        Yup SQ please
        DD 1990 CQT 800+HP SOLD
        1/4 mile 10.70@135.66
        (SOLD)
        http://www.youtube.com/watch?v=Yy-YlssmSfY
        http://www.youtube.com/watch?v=8XgzVJyvrfg
        2003 A6 4.2 Quattro
        97 MB S320 DD
          Dave F.
          I'd post that question up on this thread as it was the American guys that flowed it http://www.motorgeek.com/phpBB2/viewtopic.php?t=14658
          • Bram
            • Aug 2006
            • 2582
            Just saw on the Wagner Tuning website that the new Wagner Cast EM with a T3 flange is available for 730 Euro.
            Although the pictures are still from the K26 version of that same manifold.
            • A80Avant
              • 10873
              • Country: Greece
              #186
              bram,dont forget to give us feedback from the project!!
              • Bram
                • Aug 2006
                • 2582
                I will! My car is still at my tuner, because we got a delay with mapping the ECU. My ABY ECU did not seem to give any signal to the WGFV, so I had to buy another one. I really doubted to go for VEMS, but that was a bit too expensive at this moment of the year for me This also indicates my RS2 turbo was not the problem after all, because I thought the turbo was not able to produce any boost. Therefor I bought the GT3071R instead, which I will probably will not regret in the end I hope. :mischeif:
                However I will update you all in my car topic once I have my Avant back
                • Bram
                  • Aug 2006
                  • 2582
                  I found another nice picture of comparing the RS2 EM with the Wagner cast EM
                    Ah that reminds me! :mischeif:
                    Bram did you you get your car back so you got some new pics?
                    • Lupo911
                      • Apr 2005
                      • 312
                      here the Evo Manifold with T3 Flange...
                      • Bram
                        • Aug 2006
                        • 2582
                        Yes I got my car back a few weeks ago. However i had no time yet to take proper pictures as it is raining a lot these days in NL and I have been traveling a lot for my job.
                        Maybe this afternoon I will take some more pics and start my own project thread.
                        • Bram
                          • Aug 2006
                          • 2582
                          Ow darn.....if I would have had more patience I would have bought the T3 version in combination with a GT30 today.......NICE!
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #193
                            my next plans!!!...hehehe
                              Carsten: Am I correct in thinking that when you designed the casting for the EVO manifold, you thought ahead and made the turbo flange area large enough for both the K26 and T3 hot-sides? From the photo, it looks like only difference between the two versions of the EVO are the machining around the outlet, i.e. the T3 manifold has to have more machining (to open the discharge area up and locate the holes for the studs).
                              Either way, kudos to you.
                              Dave F.
                              • Lupo911
                                • Apr 2005
                                • 312
                                Carsten: Am I correct in think and when you designed the casting for the EVO manifold, you thought ahead and made the turbo flange area large enough for both the K26 and T3 hot-sides? From the photo, it looks like only difference between the two versions of the EVO are the machining around the outlet, i.e. the T3 manifold has to have more machining (to open the discharge area up and locate the holes for the studs).
                                Dave F.
                                Yes, you are rigth, we designed the Flange Area a little big Bigger, always in Mind to use a OEM Garrett GT30.
                                The T3 Flange is machined, its the same Casting.
