3b backbox
  • Dan_s2_coupe
    • Aug 2006
    • 482
    3b backbox
    will a 3b backbox fit a ABY
  • Jas11n
    • 5067
    Slightly different part numbers between them.
    My bro has a scorpion aftermarket SS backbox on his ABY that originally came from a 3B, it sits a tiny little bit **** eyed, but fits none-the-less.
    No idea about the OEM boxes, someone else may know.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • AndyP
      • 6049
      Does he want to do a swap? I have a Scorpion back box from an ABY on my 3B and that fits a bit wonky too.
      • Jas11n
        • 5067
        I will ask him Andy
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          7A/3B/ABY Coupé rear boxes are interchangable AFAIK.
          Robo used my old 7A one on his ABY for example.
          SS
          • Dan_s2_coupe
            • Aug 2006
            • 482
            its just i have seen a scorpian back box 4 a 3b and want 1 4 my aby
            how wonky does it sit
            • Jas11n
              • 5067
              If you can hang on until later this afternoon, I'm popping down to see him and will take a picture.
              Jas..
              • Paulgo
                • Jan 2005
                • 498
                I wouldnt mind a scorpion back box for my 3b!
                Paul
                • Dan_s2_coupe
                  • Aug 2006
                  • 482
                  dibs on the 1 on ebay
                    Dibs
                    • AndyP
                      • 6049
                      This is how mine fits:-
                      It catches on the subframe too so I had to make up a rubber packing piece to stop it vibrating.
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        I thought all Scopion exhausts for the S2 were wonky. I think the car they made the original jig from was bent or something.
                        You either have the exhaust touching somewhere or have the tail pipes straight, I don't think they will do both.
                        SS
                        • s2driveruk
                          • 12696
                          sure thats not just a stretched rubber hanger. the reinforced ones held my once wonky longlife dead straight in the middle of the cutout. Found one of the rubbers near the cats wasnt attached and from there backwards everything was out of shape...
                          1992 3b S2 Coupe
                          • AndyP
                            • 6049
                            I've already tried that, it won't go up any more because it's already jammed up against the rear subframe
                            Sounds like Scorpions build quality maybe a bit suspect.
