will a 3b backbox fit a ABY
3b backbox
Tags: None
Slightly different part numbers between them.
My bro has a scorpion aftermarket SS backbox on his ABY that originally came from a 3B, it sits a tiny little bit **** eyed, but fits none-the-less.
No idea about the OEM boxes, someone else may know.2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff) -
7A/3B/ABY Coupé rear boxes are interchangable AFAIK.
Robo used my old 7A one on his ABY for example.SSComment
Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
sigpicComment
I thought all Scopion exhausts for the S2 were wonky. I think the car they made the original jig from was bent or something.
You either have the exhaust touching somewhere or have the tail pipes straight, I don't think they will do both.SSComment
sure thats not just a stretched rubber hanger. the reinforced ones held my once wonky longlife dead straight in the middle of the cutout. Found one of the rubbers near the cats wasnt attached and from there backwards everything was out of shape...sigpic
1992 3b S2 CoupeComment
I've already tried that, it won't go up any more because it's already jammed up against the rear subframe
Sounds like Scorpions build quality maybe a bit suspect.sigpic
1976 RD250E / 350LC cafe racerComment
