Have a new de cat exhaust ready to fit. have come to a roadblock how the **** do you get to the bottom turbo flange bolt
exhaust removel
They look like nice quailty and you'll find them surpriisinly usful on other jobs, they should also last a lifetime if they're that expensive.
That nut is a total ball ache with a stock down pipe, I refused to be defeated when I first removed one from a 3B and made a short spanner with a load of material ground out of the neck so I could heat it up and bend it. You just need a cheap spanner you don't mind attacking with a grinder and MAP gas.
The nuts aren't normally tight, so I put two other's back on to hold the down pipe up whilst I got that one off.
Though before you ruin a good 17mm spanner check the size of the nut using a socket, I've found 15, 16 and 17mm nuts in that location depending on who's been in there before.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
Yes have seen some home made spanners what ever works hey.. thinking i may still have to with these..
Yes Dave mentioned could be a different size so will check before attacking any spanners.. thanks for advice and hopefully with get sorted when they arrive.. will update ?
Sent from my iPhone using Tapatalk93 ABY S2
I had this problem many years ago, I ended up using cheap spanner’s and chopped them with grinder and a welder I cut the spanner in half and used some 12mm exaust hanger bar one at 90 open end and the closed end bent like moon spanner. Also I used some penetrating fluid all best Michael
Originally posted by mac2226 View PostI had this problem many years ago, I ended up using cheap spanner's and chopped them with grinder and a welder I cut the spanner in half and used some 12mm exaust hanger bar one at 90 open end and the closed end bent like moon spanner. Also I used some penetrating fluid all best Michael
Tools made to remove exhaust what a ballache
- 2 likes
