exhaust removel
  • nw66
    • Apr 2023
    • 135
    exhaust removel
    Have a new de cat exhaust ready to fit. have come to a roadblock how the **** do you get to the bottom turbo flange bolt
    93 ABY S2
    • Dec 2017
    • 6006
    Obstruction ring spanners. I bought an Elora one specifically for this job. Some cheap ones are too thick to fit.
    • nw66
      • Apr 2023
      • 135
      Did you go from the top or underneath? both seem light years away to achieve…
      93 ABY S2
        • Dec 2017
        • 6006
        Remove the airbox completely and work from the top. I still have a scar on my thumb where the spanner suddenly slipped doing this job a few years ago
        • nw66
          • Apr 2023
          • 135
          Yeah have removed airbox already just this poxy one left.. slipped spanner scars badges of honer lol
          93 ABY S2
            • Dec 2017
            • 6006
            If it's not been swapped, I seem to recall the most awkward one is a smaller size.
            • nw66
              • Apr 2023
              • 135
              All came undone really easy so yeah not sure.. the 3 i have done are 17mm
              93 ABY S2
              • nw66
                • Apr 2023
                • 135
                Audi special spanner the ******s
                93 ABY S2
                • nw66
                  • Apr 2023
                  • 135
                  Found these on Amazon so hopefully will work.. thanks for your input Dave top man…
                  93 ABY S2
                  • K Simmonds
                    • Dec 2007
                    • 7633
                    They look like nice quailty and you'll find them surpriisinly usful on other jobs, they should also last a lifetime if they're that expensive.
                    That nut is a total ball ache with a stock down pipe, I refused to be defeated when I first removed one from a 3B and made a short spanner with a load of material ground out of the neck so I could heat it up and bend it. You just need a cheap spanner you don't mind attacking with a grinder and MAP gas.
                    The nuts aren't normally tight, so I put two other's back on to hold the down pipe up whilst I got that one off.
                    Though before you ruin a good 17mm spanner check the size of the nut using a socket, I've found 15, 16 and 17mm nuts in that location depending on who's been in there before.
                    1990 B3 2.0 80 quattro.
                    1992 C4 2.8 Avant quattro
                    1994 MTM RS2.
                    1998 B5 TDI quattro Sport.
                    2000 B5 TQS.
                    • nw66
                      • Apr 2023
                      • 135
                      Yes have seen some home made spanners what ever works hey.. thinking i may still have to with these..
                      Yes Dave mentioned could be a different size so will check before attacking any spanners.. thanks for advice and hopefully with get sorted when they arrive.. will update ?
                      93 ABY S2
                      • mac2226
                        • Jun 2008
                        • 1289
                        I had this problem many years ago, I ended up using cheap spanner’s and chopped them with grinder and a welder I cut the spanner in half and used some 12mm exaust hanger bar one at 90 open end and the closed end bent like moon spanner. Also I used some penetrating fluid all best Michael
                        • nw66
                          • Apr 2023
                          • 135
                          Yes gave a good dosing of gt fluid actually surprised how easily they came undone just this last *******.. thanks for your advice really does help getting everyones input..
                          93 ABY S2
                          • nw66
                            • Apr 2023
                            • 135
                            Finally got old exhaust off ready for new de cat to be fitted.. thanks for everyones help with this was invaluable..
                            93 ABY S2
                            • nw66
                              • Apr 2023
                              • 135
                              Originally posted by mac2226
                              I had this problem many years ago, I ended up using cheap spanner's and chopped them with grinder and a welder I cut the spanner in half and used some 12mm exaust hanger bar one at 90 open end and the closed end bent like moon spanner. Also I used some penetrating fluid all best Michael
                              Tools made to remove exhaust what a ballache
                              93 ABY S2
