Me again.
In reassembling the injectors & rail, the banjos leaked but I had used the original aluminium sealing rings (bad practice I know). So I got a set of CU rings and it was actually worse. I took them out and could see under magnification some had poor joint faces across the diameter. So I prepared a set of 4 by using fine emery to make the best ones perfect. Refitted and almost perfect but there is still a slight weep under the front banjo where it faces the rail ie not between banjo and bolt head. You can see from the pics the rail does have some corrosion. The fuel pressure on this rail is immense so the slightest flaw and it wont seal. I also include a pic of a larger joint ring, same ID but would the larger OD help or allow more opportinty for not seating correctly
Does anyone have an experience / tips / tricks on making this fuel rail face smooth. I seem to be losing the plot on the basics as I get older...
