034 donwpipe-exhaust EM combo
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    HELLO guys, what do you think about this??
    http://www.034motorsport.com/product...roducts_id=138
    i need buy one very good exhaust manifold and a good 3" downpipe too of course and i have in my mind buy the RS2 EVO EM from wagner,and the downpipe from super sprint or the stock location turbo downpipe from 034 too....
    but my questions is if i will have a lot of problems for mount it with this "header" EM with the original MAF and mi AIR filter Pipercross or RS2 airbox ?????????
    someone had bought this and have it mounted??? these items(DP and EM) are plug-play and have a nice price for bought together¡¡ or better i forget it and finally buy next summer the RS2 EVO em with other very good downpipe???
    thanks in advance for the replies
    RS2 EVO has stock downpipe position.
    The 034 item is a good item but you need to buy the brace to the manifold to prevent cracking.
    • Bram
      • Aug 2006
      • 2582
      Do not buy the stock location turbo downpipe from 034. It will hit the subframe on you S2 when you will use a Garret turbo. With a KKK turbo its also too close to the subframe, because the engine needs to have space to move.
      The stock location turbo downpipe from 034 is made for an UrS4 setup.
      I learned it the hard way
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        thanks for both for the replies and helped me
        one thing i know - i will not buy alone the stock downpipe for my 3b like "bram" said.
        Jamo if the brace its not very expensive aiway continue been a good price for both things together and the "header" EM looks very good...
        • Jonas_R
          • 3781
          • Country: Denmark
          I got the 034 3" turbo back system and mine does not hit anywhere.
          Only problem was with the rear axle, since my car is lowered.
          Sleeper S2 Avant +450
          A6 Avant 2.7t Stage 3
          Audi S2 Coupe RS2'ed
            Did you buy it from Corey? If so it's a different system and not the same one as 034 sell.
            • Jonas_R
              • 3781
              • Country: Denmark
              Jamo: It was shipped directly from 034motorsport to me. So yes it was the system that Corey sold on here. They even sell it on 034motorsport.
              http://www.034motorsport.com/product...roducts_id=505
              http://www.034motorsport.com/product...roducts_id=504
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                OK.gOod for know aniway
                argh¡¡ i dont know what i will do with nothing
                  Corey's systems aren't made in america they are made by a local U.K exhaust firm AFAIK.
                  I don't know which company however.
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    Jonas's system was an 034 item, this was before we were manufacturing our own systems
                    Corey
                    01636 822288
                    • Bram
                      • Aug 2006
                      • 2582
                      The "stock location" 034 Motorsport DP fits ok with the k24. With the Wagner EM + Garret GT3071R it hits the subframe of my Avant.
                        Bram have you got any pictures of where it hits? also are you running a dual mass flywheel or single mass?
                        Reason I ask is regarding the gearbox spacer.
                        • UR-S4
                          • Sep 2005
                          • 159
                          034 3" downpipe on stock rs2 turbo
                          034 3 " replacement is a poor fit on an s2.sits hard on the subframe.On matts2s i had to elongate the flange holes to allow a few degrees of "twist" that then allowed it to clear.Also had to weld in a lambda probe boss as it was missing.Then access to the mounting flange bolts is nigh on impossible!And whilst having a rant the exit angle is not ideal(for an s2)Well made though,just not for an s2!!!
                          AKA "THE THREAD KILLER"
                          99 A6 V8 saloon
                          85 UR Quattro
                          01 Sharan v6 4motion
                          91 Golf gti cabrio sportline
                          95 Audi 80 DS2 saloon. project "SWEEP"
                          95 Audi 80 quattro v6.(but i have a 3b engine sat on the floor)protect "SUE"
                          • QuattroFever
                            • May 2006
                            • 1360
                            what size is the stock downpipe underneath all that insulation sh**e
                            Volcano ABY coupe
                            Ant
                              2.5 inch
                              Cheers Jas won't be getting one of those then!
