I'm having some problems with the small wastegate pipe between the downpipe and the wastegate it does not fit without bending the flex pipe a great deal.
I can properly just squeze it on, but I'm afraid that it will ruin the flow.
I have to press the flex pipe downward and that means that the pipe inside the flex pipe wont be pointed straight at the hole in the downpipe but will be offset from the center by 10-20 mm.
Should I worry about this and get a new pipe made or just bolt the sucker on?
