3" Dp?
  • adamw
    • Dec 2005
    • 348
    • Country: Shetland Islands
    3" Dp?
    hi
    after a long time thinking about my exhaust and what to do with it, i have settled on a design.
    i spoke to a guy about welding up a 3" ss system with 2 boxes... the only problem is he aint keen on makeing a 3" DP?
    so im on the look out for a 3" DP with/and separate WG (stock location)
    i know a few guys on here can/know someone that can make one... so if you are intreasted give me a shout
    cheeRS adam
    RS2+
  • Bubbel
    • May 2008
    • 28
    • Home: Spain Current: Germany
    Iam interested too
    Stock Location Rs2 Turbo 3"
    • adamw
      • Dec 2005
      • 348
      anybody?
      cheeRS adam
      RS2+
      • lind4hl
        • Jul 2008
        • 2465
        i would need to have an car in my workshop to make an new downpipe since mine has been sold..
        but if some swede have an car that wants an 3" downpipe and are willing to take the car down here i would gladly do it.
        • adamw
          • Dec 2005
          • 348
          have u sold your rs2?!
          cheeRS adam
          RS2+
          • lind4hl
            • Jul 2008
            • 2465
            no, but my DP.. the car has no engine in and no oem exhaust manifold turbo etc etc. so i cant make an weld jig.. i wouls need another s2/ rs2..
            • adamw
              • Dec 2005
              • 348
              would you know where i could find a DP and WG just like the one you made?? or who could make one?
              cheeRS adam
              RS2+
              • s2martyn
                Banned
                • Apr 2008
                • 408
                i will have 8x 3" downpipes made from s/s by the end of next week,we have just finished the prototype..
                they are for stock location turbo,s2/rs2,coupe/avant and will have the option for a flexi joint if you wish...they all have 3 lambda/oxygen/egt sensor fittings in them 2 being in the header 1 in the lower section,these can be supplyed with bungs if you do not need all 3..
                also available with v band etc
                units can be custom made also..please pm if any interest
                • lind4hl
                  • Jul 2008
                  • 2465
                  martyn:
                  304 or 314ss??
                  • adamw
                    • Dec 2005
                    • 348
                    @martin. pm sent
                    cheeRS adam
                    RS2+
                    • europeanme
                      • Oct 2005
                      • 3817
                      I am hoping to get a 3" DP/system quoted for by next weekend...I will share my results when I get them...
                      • adamw
                        • Dec 2005
                        • 348
                        ok thanks. i just got a quote of £207 for 3m of 3", 1 90 elbow and 2 45 elbows?
                        cheeRS adam
                        RS2+
                        • sjw185
                          • 1175
                          Is that just material quote or fitted to boxes etc? seems a bit steep?
                          Was looking at the Jetex site:
                          Ive got a scorpion system "middle and backbox" that I want to join up to a 3" downpipe and a 3" pipe to fit to the scorpion middle box doing away with the double pipes and decats etc
                          cheers
                          • adamw
                            • Dec 2005
                            • 348
                            just material! i was looking on www.solid-fabrication.co.uk and thay were quoted me £110 ish
                            cheeRS adam
                            RS2+
                            • adamw
                              • Dec 2005
                              • 348
                              whats the best type of s/s to make a DP with? because i heard 304 will crack under the heat? is 316 the best to use?
                              cheeRS adam
                              RS2+
