Exhaust to boomy and loud
  • Jonas_R
    • 3781
    • Country: Denmark
    So I think I'm getting old, but my exhaust is driving me crazy since it is makes to much noise and it is also to boomy at 3000 RPM.
    It is 3" turbo back SS exhaust with cat, and a muffler at the middle from siemens and also rear muffler from borla.
    I was thinking that I could go 2.5" or 2.75" over the rear diff since I think it is touching there, but will that make it more quite?
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    you are getting old Jonas
    i am very happy with my 3" direct sistem with no cats and no intermediate silencer,only a straight pipe to the OEM rear silencer. it is not too loud and seems to work perfectly
    • Jonas_R
      • 3781
      • Country: Denmark
      Yeah perhaps it is the borla free flowing exhaust that is the problem Anyhow it is way to noisy and it is driving me crazy.
      • Bram
        • Aug 2006
        • 2582
        I had 2 Borla silencers in my old 3" exhaust system and also found it too loud. And yes I am getting old too
        • Ross
          • Aug 2005
          • 3399
          Same here, 3" system Borla boxes on my S2 Avant and that was too loud... worst at 3k which was cruising speed! Scorpion is much better, bit of boom around 2.5-3k which is fine for me but a little more (85mph) and it's silent.
          Dropping it to 2.75" I'm sure will help, but I think changing the boxes would be the way to go.
          • Jonas_R
            • 3781
            • Country: Denmark
            I was considering getting a Simons 045-B91R rear muffler has 2.75 inch pipe, but not sure if it will help. Running a Simons muffler a the middle.
              My coupe is too noisy, same story, 034 3" turboback system with one small back box, I tried to order it with the big back box with the twin outlets but the order got messed up, I've added a small centre box from Jetex which helped a bit but it still booms, way too loud for the track too so have run a muffler on the tail pipe which messes up the power..
              • Jonas_R
                • 3781
                • Country: Denmark
                Yeah I got the 034 rear muffler with twin pipes but it is still loud as hell. I think I will try the Simons rear muffler and see if that helps on the loudness.
                • Torben.E.
                  • Feb 2010
                  • 8
                  • Country: Denmark
                  Hi Jonas
                  are your simons by any chance the round stainless ones, i made a stainless 3" with 3 round 3" simons, loud as hell, put on stock backbox, silent as a mouse.
                  • JP
                    • 1858
                    Was going to fit stock backbox back on mine and use an exhaust bypass for the times I'm on wot. As again that 3000rpm cruising starting to do my head in after 15+yrs.
                    UrS6 Stroker + HTA3586 =
                    • Torben.E.
                      • Feb 2010
                      • 8
                      • Country: Denmark
                      Stock backbox is not as bad as you could fear, it is at dual fullflow design with only a 30 degree bend in it (on a urs4)
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        Originally posted by Torben.E.
                        Hi Jonas
                        Hi Torben,
                        Running one round 3" Simons muffler as the middle section.
                        As rear box I have a Borla muffler, I believe this one to be the main problem.
                        • sam80quattro
                          • Oct 2006
                          • 1496
                          with all you old folks complaining about 3" system you'd think id be able to find a cheap 1 for sale lol
                          • Jonas_R
                            • 3781
                            • Country: Denmark
                            Yeah you should think so
                            • Jonas_R
                              • 3781
                              • Country: Denmark
                              Anyhow what are my options:
                              1.
                              Simons 2.75" rear muffler and over the rear diff in 2.75
                              2.
                              Fox 2.75 Type 13 rear muffler and 2.75 over the rear diff.
                              3.
                              Stock rear muffler?
                              Anybody using any of the solutions?
