Where is a good source of these items. Audi want almost €80 for the 4 x M10 & 4 x M8 pieces of threaded bar.
Any ideas folks or any BTDT, I damaged one of them removing it. I'm gonna take the magic wand to the others in an attempt to salvage them but if they were available new at a reasonable price that'd suit fine too.
hi shane there is a place in naas that does every kind of stud bolt and waster i will get the name of the place tomorrow ok
I don't think you want to use cheap mild steel studs for these. BTW dont forget the difficult to get to nut round the back of the turbo/DP joint is a special one with a smaller hex, a normal nut will not tighten properly
For the wastegate ones I bought a 1m length of high tensile M8 studding, get it from a reputable nut and bolt supplier and not B&Q and it will be fine, just cut it to length.
For the turbo to manifold studs, just search ebay for M10(?) exhaust manifold studs, there are loads.
