Exhaust Manifold studs for WG & turbo
  • s2_wot
    • Aug 2006
    • 2178
    Where is a good source of these items. Audi want almost €80 for the 4 x M10 & 4 x M8 pieces of threaded bar.
    Any ideas folks or any BTDT, I damaged one of them removing it. I'm gonna take the magic wand to the others in an attempt to salvage them but if they were available new at a reasonable price that'd suit fine too.
    Shane
  • vader s2
    • Mar 2008
    • 141
    exhaust manifold studs for WG & turbo
    hi shane there is a place in naas that does every kind of stud bolt and waster i will get the name of the place tomorrow ok
    paul
    • s2_wot
      • Aug 2006
      • 2178
      Cheers Paul
      Shane
      • 220bhp
        • 2578
        • Home: United Kingdom
        Pete reeve at quattro corner,thats where I got mine.
          I don't think you want to use cheap mild steel studs for these. BTW dont forget the difficult to get to nut round the back of the turbo/DP joint is a special one with a smaller hex, a normal nut will not tighten properly
          • AndyP
            • 6049
            For the wastegate ones I bought a 1m length of high tensile M8 studding, get it from a reputable nut and bolt supplier and not B&Q and it will be fine, just cut it to length.
            For the turbo to manifold studs, just search ebay for M10(?) exhaust manifold studs, there are loads.
