yep
is this usual behaviour from the S2????
Sold ABY-stockComment
It seems to me more than a coincidence that some random bunch of franchised (pipe) benders took your car part and now it ain't right, I'd take it all apart again and make sure its carefully back together the way Herr Audi intended.
As said above you're lucky you've not got a damaged engine, if it was me I'd be pis$$ed
Imola B6 S4 AvantComment
What would happen if boost pressure was routed to the top nipple on the wastegate? Just wondering if somebody looked and thought something must go on there.Current-2004 Impreza PPP wagon
Same as if there is nothing connected to the wastegate at all...
Boom.Comment
It's cutting fuel because it is going above the programmed boost ~14 psi, you said you were hitting 30, so it's doing its job to stop your rods looking like bananas.Comment
does it sound like a remap will cure this? as thier is nothing wrong with anything on my car at all, ive checked and checked again and again,
i was reading about an evo and a scooby that had this problem after a decat and they said they needed a new coilpack, could this be true on the s2?? maybe ive had a problem a while and now the exhaust has made it noticeable through the turbo spiining up alot quicker??
also how much are coilpacks and who good to get them off??
thanksComment
Disconnect the N75 valve and see how much boost you have.
The problem is not a remap, there is something mechanically wrong with your car.Comment
ill take disconnect n75 today and come back to you, i have a slightly frazzled lambda sensor wire cover maybe from when they fitted a second lambda in the downpipe, the wires look ok but if they are damaged inside could a bad lambda make the car run with the above symptoms??Comment
I've replace all of them for peace of mind ;they was 18 years old coil packs
