I had a bit of a problem with fitting the MAF and air filter with the new manifold, so my friend just 'knocked' this up for me, still needs some work and adjusting but it looks the nuts. Excuse the writing on it, he has to name each part he makes for the car! LMAO
Inlet duct
Inlet duct
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm -
excuse the brush in that pic, it was used as a blank!!Attached Filessigpic
Audi UR Quattro
andAttached Filessigpic
Audi UR Quattro
Audi B5 RS4 645ps 911nmComment
LOL, same here
www.MRCTuning.com
info@MRCTuning.com
Workshop DirectionsComment
Well to be honest thats as good as its gonna get. Room is a bit tight behind the headlight, about 2.75" to be precise, that box just touches the very back with the plastic removed from the lamp!!
So until i can afford anything better, thats how its staying. I really would like to put it in on the boost side, but i cant belive that the plastic tube will take the hose clip forces.sigpic
Audi UR Quattro
it looks a bit wierd, but i guess thats because the room you have between your turbo and headlight
Hopefully it just works good.
CeesComment
Come on guys, positive comments also welcome!!sigpic
Audi UR Quattro
....welds aren't that bad....
just kidding Tom. Don't get frustrated. It might work decently untill you find a definitive solution. Anyway the vacuum test isn't a joke.
You might find it works better then we have thought it would...
MarcoComment
You could keep your sandwiches in it?
What's the pipe coming out of the top? DV?Comment
A straight piece of tubing connecting to the MAF and then to the filter/filter box without steps and sharp edges....
Actually impossible.
Originally posted by Greg_Swhat would be the better way to design it?
smooth rounded edges, with an elipitical cross pipe?
GregComment
