Injector seats - where to buy?
  • Rusty
    • 18953
    Well just replaced these and one of the little feckers snapped and fell onto the head Luckily the pieces were large and the valves pretty much shut. Still, an hour and a half and one inlet manifold removal and refitting after I started a 15 minute job, I'm done
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      #32
      Yes. Good thing you didn't turn that engine key...
      • Rusty
        • 18953
        Yes, I wasn't amused
        • irishs2
          • Apr 2009
          • 2455
          I went at mine yesterday, changing them to be on the safe side besides my IM was blasted so who knows how damaged those inserts are.
          I had great difficulty getting them out, My extremely snug fitting allen socket just rounded the insert, leaving me to melt a section, by running a hot screwdriver along an edge taking care not to damage the threads to relieve pressure
          Was only successful 3/5 times though
          No threads were harmed but it took a long time to clear it out.
          Eric
          95 S2 Avant under rebuild.
            Originally posted by irishs2
            I went at mine yesterday, changing them to be on the safe side besides my IM was blasted so who knows how damaged those inserts are. I had great difficulty getting them out, My extremely snug fitting allen socket just rounded the insert, leaving me to melt a section, by running a hot screwdriver along an edge taking care not to damage the threads to relieve pressure.Was only successful 3/5 times though No threads were harmed but it took a long time to clear it out.
            Thanks for that. I *was* contemplating re and re'ing my inserts insitu but after that and the other "broke my insert" story, the intake is going to come off for this one.
            Dave F.
            • blackS2
              • Apr 2010
              • 455
              oh I remember... I needed a few hours to clean out the old silicone but it was easy to get the seats out... but I put the inlet manifold out first...
              no fun..
              [__]=oooo=[__]
              • Rusty
                • 18953
                Mine aren't as bad as the 5 above but here's the one that broke and the bits that fell out. The other one was broken when I tightened them up a bit a while back, luckily I was able to completely remove it after hearing the crack and remove the section.
                • Rusty
                  • 18953
                  Could get some of these made out of brass to prevent them breaking in the future. Might be about £40-50 a set but that's rather cheaper than engine damage
                  • GazzaG60
                    • 4133
                    never broke one. don't be heavy handed. slight tighten then remove.
                    these are same in any digi golf gti or g60.
                    • prj
                      • Mar 2010
                      • 6308
                      These never come out in one piece.
                      If they do, it means they weren't sealing, as they always should be fitted with a sealant to prevent a massive boost leak.
                      • Rusty
                        • 18953
                        I used some Loctite black gasket sealant when I put them back in, so the new ones are all nice and snug now
                        • AndyP
                          • 6049
                          Told you so
                          • Rusty
                            • 18953
                            They were fine the first time round... only a couple of months back. It was the one on cylinder 5 that snapped, more than likely because access to that one wasn't as good as the rest
                            Have to say, if I was doing this on another car, I'd just pull the IM off, although with the radiator air guides in place, this would be a lot more difficult than it was on my car with it's no nonsense engine bay.
                            • Rusty
                              • 18953
                              Anyone know the thread for these?
                              • ColonialNomad
                                • Feb 2015
                                • 392
                                • Home: United Kingdom Current: China
                                #45
                                I'm only reading this thread because I was hoping you were looking for ejector seats and there had been a typo.
