MAF cleaning
  • Audi Parts Guru
    • 1317
    MAF cleaning
    I'm going to clean my MAF tomorrow using IPA.Has anyone else tried this using IPA or any other cleaning agent ?
    S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
  • Mark Halligan
    • 2001
    Well aint that weird, so am I
    Great minds think alike
    I'm going to use something I bought today for the job, a can of Castrol metal parts cleaner, it says on the tin that its good for brakes, sparkplugs and electrical switches amongst other things. Hope it works cos I'm convinced my MAF is playing up.
    Whats IPA?
    Mark.
    Mark - Modded
    • Audi Parts Guru
      • 1317
      Originally posted by Mark Halligan
      Whats IPA?
      Mark.
      Isopropyl alcohol.............Maplins sell a 1 litre can for £10
      • AbsS2
        • 285
        If you can, TAKE PICS!. We need such guides for us non techy nonces
        Coupe
        • jubjub
          • Nov 2003
          • 1239
          sorry lads but bit of a novice, is the maf easy to take of and how do you clean it?
          • Glen Chamberlain
            • 375
            I cleaned my maf plug with common brake cleaner and its been fine since! high recomend it!
            Money is everything! Second to Power of course!!! But money breeds power??
              Clean the connector contacts too, I'm absolutely convinced that this is what has fixed the poor running problems and overboostcutout at 5lbs boost that has be plagueing my car since I got it over a year ago.
              Its not that easy to effectively clean the inside of the female side of the connector, you can wash off the dirt but there may still be a layer of oxidation on the contacts, there are dissimilar metals at work here..
              I did it the first time with carb cleaner and followed it up with silicon grease but it didn't last long, I think, with a bit of vibration, the connector moves it'self back to exactly the same position and the fault re-appears..
              I got some special contact cleaner and conditioner called Deoxit made by Caig Labs. Distributed here by Probus Electronics.
              This stuff is amazing, if you put it on the ends of your torch batteries it makes the torch brighter, I've been going round my car fixing things with it, I sorted out my numberplate lights that were all corroded up in seconds.
              It makes you headlights brighter, I did the ECU connector with it too. Its completely non aggressive to metals, the spray is a 5% solution, it would probably work for the MAF wire too.
              Caig Laboratories Deoxit Power Booster
              Probus Electronics Ltd
              Findon, Southill Lane
              Eastcote
              Ruislip
              HA5 2EQ (Road Map)
              Middlesex
              Tel: 020 8866 7272
              Fax: 020 8866 2999
              Phone up and ask for Warren
              • jubjub
                • Nov 2003
                • 1239
                am i right in thinking the MAF is the little black box connectedto quite a big pipe just before the air box, on the left of the engine as you look...?
                • Mark Halligan
                  • 2001
                  Newsh,
                  Thanks for the info on the Deoxit cleaner, I think I might try this stuff out, I've just cleaned my MAF wire with Castrols metal cleaner and while its nice and clean in there now I've noticed that the front face of the wire (up wind of airflow) is noticeably darker with deposits than the back (down wind side) which is nice and shiny. And my attempts to clean it dont seem to have made much difference visually .
                  How does it come, in a spray can or tin and how much?
                  Cheers,
                  Mark.
                  P.S. Abs, I would have took photos, but my MAF is in a different location cos of my mods, they would'nt help much mate
                  Mark - Modded
                  • Glen Chamberlain
                    • 375
                    You'd be dead right there m8! Thats the little trouble causer right there! I've also slightly and i mean slightly twisted the pins in the MAF with a pair of long nose pliers to make it a tighter fit in the plug. BE CAREFULL! DON'T ATEMPT THIS IF YOU ARE IN ANY DOUBT COS IF YOU BUST IT, IT'S ARROUND £150 NOTES FOR A NEW EN!
                    Fixed it for me though!
                      Newsh,
                      Cheers,
                      Mark.
                      Several ways to buy it, check the CAIG site, I bought an aerosol and a pen, you can also buy wipes and little bottles with a brush, up to you, I did a fair bit of reading about the products before buying, there's a tutorial on the site. Oh yeah, not cheap, I think about £12 a can, worth it though..
                      Dont try buying on the Caig website though cos they have a distributor deal with Probus for the UK so the sale will not go through, (I wasted a bit of time doing that)
                      Tutorial
                      • Mikes2
                        • 1704
                        If you're using IPA, buy it from a chemist. You get half a litre for a few quid.
                        When I did mine I left it to soak overnight
                        Mike
                        http://www.s2-audi.co.uk
                        • audiman
                          • 4827
                          Heres a pic, gonna try and clean mine today. I really dont think that it is that playing up, but I am now clutching to straws to find my running problem.
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • audiman
                            • 4827
                            Please ignore my engine bay mess, this was not long after doing the head job and its not all back in there. Plus i cant be arsed to polish it
                            Audi UR Quattro
                            • AbsS2
                              • 285
                              Are you guys gonna clean just the contacts? if so, are u gonna dip the both sides of the connector ito this soulution? I ve tried to clean it but the female side of the connector is a real PITA. the only way i can think of making sure the solution can get everywhere is to dip the connector into the soultion. But i think that would be a bad idea . Maybe im wrong.
                              What else you guys gonna clean on it?
                              Coupe
