Headlining coming apart
  • mcandmar
    • Apr 2004
    • 5118
    Has anybody else had this happen? The fabric has started to separate from the backing and peel away. I thought it must have got damp but its bone dry
    Also if anybody can recommend any spay glue that won’t stain fabric it would be much appreciated.
    Cheers, Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    u have to change the fabric cos what make it fall that the foam between the fabric and the panel has come apart , which color is the trim of your headliner? , spray i think 3m or wurth is fine. i bought one french kind last time and i ended up buying new trim again cos it didnt stick as it supose.
    • Skull
      • 3506
      • Country: Slovenia
      Remove it as soon as possible. When it will be all apart, u will have some problems. The foam is so sticky, it sticks to everyhing and it is a major PITA to clean. Do not separate the cloth from the foam!
      Audi Quattro WR
      • AndyP
        • 6049
        Cheers, Mark.
        Did you get this fixed? Mine has started doing the same and I'm looking for a suitable spray adhesive to fix it.
        • mcandmar
          • Apr 2004
          • 5118
          I bought a can of spray gue from ebay, its the stuff people use to stick carpet onto sub boxs, white sticky stuff when sprayed. It lasted a good while but it starting to seperate again in places, i think the key is to remove as much of the old foam as possible, then stick the fabric back on. Its not a perfect solution by any means, if i was bothered about it i would buy new fabric and recover the panel properly.
          • vader s2
            • Mar 2008
            • 141
            i have the same problem. mark
            • djh
              • Jun 2011
              • 1622
              • Home: United States Current: United Kingdom
              get a proper contact adhiesive (Spl) as the spray glues only last a few months, there are some good brands if you look around
              • s2driveruk
                • 12696
                have the same issue unfortunately though i think min was caused by getting a bit damp last winter
                1992 3b S2 Coupe
                • benntenn67
                  • Jun 2009
                  • 859
                  This is what retrimmers use http://www.martrim.co.uk/catalogue/g...-adhesives.htm
                  Audi S2 Coupe 1995
                  VW Passat GL5 (hatch) 1986
                  Carrera Subway 8
                    • 12431
                    I used some spray carpet glue and worked a little too well, I made the material on sunroof trim little too tight and broke plastic clips so watch out when you do it.
                    • Oily
                      • Jun 2010
                      • 48
                      I replaced my headlining & sunroof pannel in 2010 & did a how to guide.
                      The thread is here
                      My how to guide is here
                      Hope this helps....
                      • re2500
                        • May 2007
                        • 2185
                        Mine started separating in my coupe, at the back near the top of the hatch opening. I found glue wasn't working so I removed the plastic trim that covers the edge and stapled it to the backing. The trim covers the staples. It ain't comin away now!!!!
                        "Difficult is worth doing"
                        • rs2coupe
                          • Oct 2004
                          • 1782
                          • Home: Trinidad and Tobago Current: United States
                          Nice write up there
                          Cheers mis amigos,
                          _Anton
                          • andy10v
                            • 5996
                            I like it, that is my kind of fix!
                            Sold ABY-stock
                            • LHD_Kid
                              • May 2006
                              • 3697
                              I was thinking, since I am also having similar issues....
                              Can anyone think of a reason why the old material and foam cannot be cleaned off and the headlining board "flocked"?
                              You could then do the sun visors in matching flock.....
                              What do you think?
