Went to the car this morning to find water in the back of the car (see pic), the head linning was dry and every where else that i could see, im stumped with this one any thoughts please
Oh and also (second pic) water o/s boot floor, around the light lens has just been re-sealed and feels dry,washer bottle maybe? again any thoughts?
Tom
i have a tailgate seal leak whenever i wash the car it comes in.Although i bought a new seal it still leaks after a while as the top 2 edges get more pressed overtime and flatten the seal.However what i did was manage to adjust the tailgate closure to be more tight (four screws on top and the locking mechanisms on bottom) as well as instead of buying again a new seal which is costly,i simply unhooked the seal and gave it a 10cm turn so as the top 2 edges of flattened seal be placed into different positions where water is much more difficult to get in and build up.So no leaks now!
After fitting the new seal i still had a leak on the o/s so it was time to strip the lot and get to the bottom of this.....If you look at the picture you can see a hole toward the top,thats where the water was coming in,it would run down the tail gate between the rubber and should end up going to the road but for some reason a small amount would divert through that hole there was no plug there so no idea if it should have one or not, so my solution was to plug the hole with a plastic plug the silicone it and hay pressedo NO more leaks
Well done Tom, its good to get these things sorted eh?
I've got a puddle in the drivers footwell, hopefully its just down to the stuff I've removed ready to get the bonnet painted, washer jets etc..
