Audi 80 b4 bordcomputer
  • spyros80
    replied
    BC cables
    For example I have this photo.
    Number one goes behind the instrument cluster.
    Number two is the stecker with the functions in the wheel
    Number four (yellow) is probably the consumption cable you said
    And number three, what is it? Where should I put this?
  • spyros80
    replied
    What do you mean? Can you tell me a code or something? Also, the stecker is the same for all the B4's?
  • Skull
    replied
    Originally posted by spyros80
    Thank you very much. Do I have to know anything else about the connections before I bought it? Note that my car has already an auto check system. I need only the bordcomputer.
    if you already have the autocheck you only need to connect this wire. but pay atention to what BC you buy, because not all have the AC inside!
  • spyros80
    replied
  • Skull
    replied
    this is the consumption signal wire, some cars have it just yellow, some yellow/green. to get the BC working, you only need to connect this wire. All the other signals come from the speedo cluster. just find the black connector under the steering wheel and you will see it.
  • spyros80
    replied
    Audi 80 BC
    Dear Skull23,
    Iam very glad chating you. By the Way you have a very nice car and I would like to ask you a few things if you don't mind.
    Firstly, I want to tell me what parts did you order from audi, in order to install the S2 side skirts. They are fabulous. Please tell me what to ask for.
    Secondly, I installed an external temperature gauge and I can't connect the gray wire, because I don't know where to put it.
    Finally, do you have any photo during the BC installation, because I don't thing that ADA motors have the specific cables?
    Iam sending you a photo of my baby too. It is 1.6, sport edition, with an ABT kit reaching 125 ps!!! Know Iam ready to install a final exhaust barrel from SUPERSPORT.
  • Skull
    replied
    yes, plug and play.
    for the BC you only need to connect the yellow wire to the yellow wire above the footwell, connecting the AC is a little more time consuming, did you use the search function?
  • spyros80
    started a topic Audi 80 b4 bordcomputer
    Hello,
    Does anyone knows, how can I install an Auto/check tripcomputer to an audi 80 b4 1.6 (ADA motor)? Is it feasible such an installation?
