Audi 80 b4 bordcomputer
  • 3db
    replied
  • 3db
    replied
    I assume he's talking about MSA12/MSA15 TDi 68pin ECU. Yes, pin 9 is the consumption signal. In Audi 80 it's left unconnected. Go directly to the ECU, it's behind heating box in passenger's footwell. Signal output is square wave with varied pulse width and frequency.
    And yes, it is possible to install OEM board computer in Audi 80 TDi's. You just have to have a 68pin ECU or install one, if you have older one. I have made adapter for the consumption signal, at least 4 cars including mine in Latvia is using it with no problems.
    replied
    Originally posted by Catalin_BN
    What signal comes from the ECU ? I'm trying to make a BC with arduino and this would be very helpful. Where does this Pin 9 from ECU go? Can I find it in some socket under the dash?
    What ECU are you talking about? ABY ECU Pin T55/9 is the connection to the F96 Barometric pressure sensor. The fuel consumption signal is in pin T55/31.
    REFERENCE: http://www.s2forum.com/forum/showthread.php?t=82357
  • Catalin_BN
    replied
  • mihai_antony
    replied
    Thank you!!
  • mdz
    replied
    Swap over that big white part from V6 cluster to your 7A.
  • mihai_antony
    replied
    ok
    in order to be sure, I need to move the bord computer from V6 to the 7A instrument cluster, in order to use the 7A fuel, water, acc instruments
    correct?
    Mihai
  • mdz
    replied
    Yes you can. Swap over computer unit to your existing cluster and it will work correctly.
  • mihai_antony
    replied
    Hello
    I can use a V6 bord computer and Autocheck with a 7A 20V engine?
    There will be errors on the consumption or fuel indicators?
    Thank you!
    Mihai
  • shellah
    replied
    You have to know something about electronical systems in no is possibility to broken something
  • Marius
    replied
    why?
  • shellah
    replied
    hmmm... I think it" waste of time ...
  • Marius
    replied
    does anyone tryed to use this idea from "audifieber"?
  • Marius
    replied
    Originally posted by Sküll
    Sküll, if you look to mine #33 post, you will see same link.
    share the drink
  • Marius
    replied
    you mean, 1z with ECU "028 906 021C"? I think the difference just between ECU (if we talking about putting BC).
    my 94 b4 tdi 1z with that one unit.
