How To... Remove the dashboard
This is a sticky topic.
  • John.
    • 2615
    Originally posted by Tractor Dave
    Thanks Dave.
    • John.
      • 2615
      Ok Dave, the dash is out......now for the heater box! Have released the box from the scuttle where the air intake is (directly above the motor), and in the centre of the bulkhead from the engine bay side.....but it's still not exactly wanting to jump out. Have I missed something?
        • Dec 2017
        • 6006
        Have you got air con?
        You can split the heater matrix box in half by prising off the gold coloured rectangular clips but there are a couple around the back which are tricky. If you manage to split it, you can get to the radiator without removing everything.
        • LSG
          • May 2010
          • 897
          Have you removed the glove box. I have just done my 2.3 10v and Brian smiths S2. There is a air intake or pollen filter depending on the car on the passenger side , opposite side to the fuse box under the windscreen panel.
            • Dec 2017
            • 6006
            Just been looking through my old pics and I remember that there are a couple of screws where the airbox connects to the top of the centre consul trim. If those are out and the two nuts have been removed from inside the bulkhead, as LSG says, there are two screws by the pollen filter, then from memory it should just lift up and out off the hooks. If you have aircon, the pipes connect into the bulkhead and need disconnecting first. Also, have you undone the heater water pipes? I think that's all? I did mine back in the summer. Seems ages ago now!
            • John.
              • 2615
              No AC, I'm looking to remove the whole thing as the flaps need re-foaming as well. Yes, coolant pipes are off.
              Think it's just protesting 'cause someone's trying to move it after 20 years!
              • LSG
                • May 2010
                • 897
                It maybe just were the tubes come through the rubbers they are stuck. I put a hooked tool and some wd40 to help it along. Dose it feel like its loose as there are quit a few nuts, bolts and screws to do.
                • John.
                  • 2615
                  Thanks guys, got it out. I'd missed the screw on the driver's side which holds the heater box to the lower heater ducting......I was working mainly from the passenger side so missed it as there isn't one on the N/S
                  It's out, matrix is goosed......now the great job of splitting the assembly and replacing the foam on the flaps.
                    • Dec 2017
                    • 6006
                    Horray! It's even harder getting it back.
                    • John.
                      • 2615
                      Yeah, looking forward to it.
                      • Tom_
                        • Oct 2007
                        • 1301
                        • Country: Czech Republic
                        #71
                        Any chance that someone has that PDF file with "how to remove the dashboard" All pictures are missing
                        Audi Coupe Quattro 2.3 20V
                        • K Simmonds
                          • Dec 2007
                          • 7632
                          Check your PM's mate, I've got the factory manual for your car and another member has it all on computer file which he can forward to you for a small donation.
                          1990 B3 2.0 80 quattro.
                          1992 C4 2.8 Avant quattro
                          1994 MTM RS2.
                          1998 B5 TDI quattro Sport.
                          2000 B5 TQS.
                          • Ian Simmonds
                            • Jun 2005
                            • 2858
                            There’s the old ‘heater matrix’ guide …
                            93 MTMS2 Avant
                            • Tom_
                              • Oct 2007
                              • 1301
                              #74
                              Thanks Ian, it will come in handy I guess
                              • johne
                                • Apr 2007
                                • 1406
                                Make sure when you've got it all back together that the heater unit isn't hanging on the heater matrix pipes as they pass through the bulkhead as I suspect that's the cause of a few heater matrix failures. I used a small block of wood at the base of the heater unit to support it on the transmission tunnel before doing up the bulkhead nuts.
