"Mysteries" of the C4 CEL/ Air Bag/Seat Belt warning light panel
ELD, Electronic Differential Lock is an early form of ASR, Automatic Slip Regulation.
"ELD is incorporated in the Bosch 5 ABS (introduced for the MY1996) control unit.
-ELD acts upon all four wheels on a quattro equipped automobile.
-ELD operates up to 40kmh(25mph)."
This is from the factory C4 shop manual. In the electrical wiring part of the wiring schematic there is at least one wire that connects the ABS module to the Engine control module. Maybe to signal timing retardation? That would also act to reduce power output to the wheels.
ABS/ASR has become more sophisticated as electronic throttle, steering angle sensors, body acceleration sensors, suspension travel sensors, front & rear radar sensors, Controller Area Networking, CAN, have been incorporated into automobiles.
HTH, ChrisLast edited by A1QSHIP; 1 October 2013, 18:21."Nulla tenaci invia est via"Comment
The manual is wrong. EDL and ASR have absolutely nothing to do with each other, apart from the fact that both use wheel speed sensors.ELD, Electronic Differential Lock is an early form of ASR, Automatic Slip Regulation.
It does not only retard or cut timing as that would blow up the cats very quickly on prolonged use. What it does is sequentially blends out the mixture from different cylinders, uses the semi-electronic throttle on the M5.92 ECU on said unit and so on.In the electrical wiring part of the wiring schematic there is at least one wire that connects the ABS module to the Engine control module. Maybe to signal timing retardation? That would also act to reduce power output to the wheels.Comment
Dave, Here is the picture of the aux warning lights on my UrS4 gauges, unknown year and not sure if V8 or 2.2T. I'd really like to know what the steering wheel sign was supposed to show. Also the "ASR aus" is on the aux part but on my UrS6 the ASR warning is on the main cluster. Unfortunately the main strip for the warning lights was removed before i got that cluster.
If you need this pic in better quatlity let me know, the mobile camera in these conditions was just nearly useless.Attached FilesComment
Hmm...not seen that before. I will have to see what info I might have on that.Dave, Here is the picture of the aux warning lights on my UrS4 gauges, unknown year and not sure if V8 or 2.2T. I'd really like to know what the steering wheel sign was supposed to show. Also the "ASR aus" is on the aux part but on my UrS6 the ASR warning is on the main cluster. Unfortunately the main strip for the warning lights was removed before i got that cluster..RS2'd 93 UrS4 5 spd sedan
