Is it still possible to read prj mode ECU with VCDS?
  • prj
    • Mar 2010
    • 6308
    Go to device manager, select Ross-tech direct, update driver and change the driver to the "with VCP" option.
    Or when installing VCDS uncheck the "install USB drivers" option.
    The values you are seeing are completely normal, the only thing that gets updated with engine not running is the throttle position.
    • blackS2
      • Apr 2010
      • 455
      perfect - thanks. ECU is on its way to be tested in car.
      [__]=oooo=[__]
