The parameters of the launch control with stock turbo kkk7000.
  • jonn48
    • Mar 2014
    • 92
    • Country: Russian Federation
    Guys, what parameters to use for hard LC?
    Do these
    LC ignition Retard rpm - 3800
    LC ignition cut rpm - 4000
    LC fuel cut rpm - 4100
    LC ignition angle - 7.5
    Retards work, boost 1 bar, but the rpm does not freeze at 4000-4100 rpm. The engine continues to spin. What am I doing wrong?
  • Acki
    • Mar 2014
    • 302
    Is the rpm only higher or doesn't work the cut? ign cut should hold the engine speed down - maybe not exact on the rpm you setted caused by the acceleration of all parts?!
    • jonn48
      • Mar 2014
      • 92
      Yes, the cut does not work. The engine continues to increase speed. Retard at 3800rpm is activated.
      • vwnut8392
        • Jul 2012
        • 418
        what is this for AAN or 3B? if using my stuff from 3B patch the throttle has to be pressed down above 90% for the cut to activate. this is how i keep the spark cut from interfering with daily driving since 3B has no wheel speed input.
        "The really good drivers got the bugs on the side windows." Walter Röhrl
        • jonn48
          • Mar 2014
          • 92
          AAN s6 c4
          • vwnut8392
            • Jul 2012
            • 418
            Originally posted by jonn48
            AAN s6 c4
            they are whatever you want them to be. if you want it to make 5psi you adjust till you get that, if you want 10psi at launch you adjust till you get that. there is no set in stone configuration for it.
            • jonn48
              • Mar 2014
              • 92
              I do not know why it does not work. Ign cut rpm - 4100 , ign Retard rpm 3800. Rpm do not freeze on 4100, and continue to increase.
              • Acki
                • Mar 2014
                • 302
                But does it cut the igntion or revs it up like without the mod?
                • jonn48
                  • Mar 2014
                  • 92
                  Retard at 3800 rpm works, cut-out at 4100 rpm is not.
                  • vwnut8392
                    • Jul 2012
                    • 418
                    ignition angle is ATDC not BTDC. set it to like 50 degrees than try it.
                    • Acki
                      • Mar 2014
                      • 302
                      Ign cut is only active when no knock is noticed. May you should check your engine/wiring/DTCs etc.
                      /edit:
                      Just took a look into the code, to be honest I don't see a "real" spark cut only a advance over the limits. Same for fuel cut. Don't found it..
                      • jonn48
                        • Mar 2014
                        • 92
                        Next time I will connect the emulator and try to make a video, how I change the parameters and how the work changes.
                        • jonn48
                          • Mar 2014
                          • 92
                          /edit:
                          Tried to do it on another car, the situation is the same.
                          • tekstil
                            • Jun 2011
                            • 104
                            Try increasing LC fuel cut RPM more. For me, fuel cut LC doesn't work, same symptoms as you describe here - I didn't investigate it enough though why it wasn't working. Spark cut LC works OK.
                            • vwnut8392
                              • Jul 2012
                              • 418
                              /edit:
                              thats not right. launch control spark cut happens before knock control is disabled in code. knock control is disabled only at high RPM for spark cut rev limiter and flat shift.
                              This is exactly how the whole routine works. i have commented everything that is important.
                              Code:
                              00008610          Motorsport Code
                              code:00008610
                              code:00008610          ; =============== S U B R O U T I N E =======================================
                              code:00008610
                              code:00008610
                              code:00008610          Motorsport_Features_Code:               ; CODE XREF: MAP_Sensor_Read:Jmp_M_Sprt_Code↑p
                              code:00008610
                              code:00008610          ; FUNCTION CHUNK AT code:0000866C SIZE 0000000C BYTES
                              code:00008610
                              code:00008610 C0 82                    push    DPL             ; Data Pointer, Low Byte
                              code:00008612 C0 83                    push    DPH             ; Data Pointer, High Byte
                              code:00008614 E5 3A                    mov     A, RAM_RPM_1    ; Move (Op1 <- Op2)
                              code:00008616
                              code:00008616          Hard_RPM_Limit:                         ; Spark Cut RPM Limit
                              code:00008616 B4 C8 00                 cjne    A, #0xC8, code_8619
                              code:00008619
                              code:00008619          code_8619:                              ; CODE XREF: Motorsport_Features_Code:Hard_RPM_Limit↑j
                              code:00008619 50 26                    jnc     NLS_Limiter_Crank_Angle ; -If at RPM limit go to mod crank angle
                              code:00008619                                                  ; -If below RPM limit go to launch control code
                              code:0000861B
                              code:0000861B          W_Speed_LC:                             ; Speed for launch control
                              code:0000861B 90 01 70                 mov     DPTR, #0x170    ; Speed in 2 km/h
                              code:0000861B                                                  ; XRAM=XVMESS
                              code:0000861E E0                       movx    A, @DPTR        ; Move from/to external RAM
                              code:0000861F B4 02 0C                 cjne    A, #2, code_862E ; -If below wheel speed go to launch control
                              code:0000861F                                                  ; -If above wheel speed go to NLS code
                              code:00008622 80 48                    sjmp    LC_Ign_Cut_RPM  ; Short jump
                              code:00008624          ; ---------------------------------------------------------------------------
                              code:00008624
                              code:00008624          code_8624:                              ; CODE XREF: Motorsport_Features_Code+66↓j
                              code:00008624 B4 71 00                 cjne    A, #0x71, code_8627 ; 'q' ; Launch control IGN retard RPM
                              code:00008627
                              code:00008627          code_8627:                              ; CODE XREF: Motorsport_Features_Code:code_8624↑j
                              code:00008627 40 1B                    jc      code_8644       ; Jump if Carry is set
                              code:00008629
                              code:00008629          LC_Ign_Deg:                             ; Launch control IGN angle
                              code:00008629 75 53 29                 mov     ZWOUT, #0x29 ; ')'
                              code:0000862C 80 16                    sjmp    code_8644       ; Short jump
                              code:0000862E          ; ---------------------------------------------------------------------------
                              code:0000862E
                              code:0000862E          code_862E:                              ; CODE XREF: Motorsport_Features_Code+F↑j
                              code:0000862E E5 D9                    mov     A, ADDAT        ; If ECU pin 39 is supplied with 12v go to NLS code.
                              code:00008630 B4 FF 11                 cjne    A, #0xFF, code_8644 ; Compare Operands and JNE
                              code:00008633 78 EC                    mov     R0, #0xEC       ; Move (Op1 <- Op2)
                              code:00008635
                              code:00008635          NLS_Min_TPS:                            ; min TPS for NLS
                              code:00008635 B6 C0 00                 cjne    @R0, #0xC0, code_8638
                              code:00008638
                              code:00008638          code_8638:                              ; CODE XREF: Motorsport_Features_Code:NLS_Min_TPS↑j
                              code:00008638 40 0A                    jc      code_8644       ; -If below this TPS % go to normal operation
                              code:00008638                                                  ; -If above go to NLS RPM compare
                              code:0000863A E5 3A                    mov     A, RAM_RPM_1    ; Move (Op1 <- Op2)
                              code:0000863C
                              code:0000863C          NLS_MIN_RPM:                            ; min RPM for NLS
                              code:0000863C B4 C8 00                 cjne    A, #0xC8, code_863F
                              code:0000863F
                              code:0000863F          code_863F:                              ; CODE XREF: Motorsport_Features_Code:NLS_MIN_RPM↑j
                              code:0000863F 40 03                    jc      code_8644       ; -If below this RPM go to normal operation
                              code:0000863F                                                  ; -If above this ROM go to crank angle Degree (spark cut)
                              code:00008641
                              code:00008641          NLS_Limiter_Crank_Angle:                ; CODE XREF: Motorsport_Features_Code:code_8619↑j
                              code:00008641                                                  ; Motorsport_Features_Code:code_8674↓j
                              code:00008641 75 53 52                 mov     ZWOUT, #0x52 ; 'R' ; IGN angle for NLS/Spark revlimit
                              code:00008644
                              code:00008644          code_8644:                              ; CODE XREF: Motorsport_Features_Code:code_8627↑j
                              code:00008644                                                  ; Motorsport_Features_Code+1C↑j ...
                              code:00008644 30 FC 0F                 jnb     P5.4, code_8656 ; Jump if no knock detected. If knock detected go to RPM check.
                              code:00008644                                                  ; -Knock signal from Boost processor
                              code:00008647 50 0B                    jnc     code_8654       ; Jump if Carry is clear
                              code:00008649 E5 3A                    mov     A, RAM_RPM_1    ; Move (Op1 <- Op2)
                              code:0000864B
                              code:0000864B          Spark_Cut_Knock_Dis:                    ; Spark Cut RPM Limit with knock disable
                              code:0000864B B4 B1 00                 cjne    A, #0xB1, code_864E
                              code:0000864E
                              code:0000864E          code_864E:                              ; CODE XREF: Motorsport_Features_Code:Spark_Cut_Knock_Dis↑j
                              code:0000864E 50 04                    jnc     code_8654       ; -If above this RPM knock control is disabled
                              code:0000864E                                                  ; -If below this RPM knock control is enabled
                              code:00008650 C2 EF                    clr     P4.7            ; Knock disable is sent to boost processor
                              code:00008652 80 02                    sjmp    code_8656       ; Short jump
                              code:00008654          ; ---------------------------------------------------------------------------
                              code:00008654
                              code:00008654          code_8654:                              ; CODE XREF: Motorsport_Features_Code+37↑j
                              code:00008654                                                  ; Motorsport_Features_Code:code_864E↑j
                              code:00008654 D2 EF                    setb    P4.7            ; Knock enable is sent to boost processor.
                              code:00008656
                              code:00008656          code_8656:                              ; CODE XREF: Motorsport_Features_Code:code_8644↑j
                              code:00008656                                                  ; Motorsport_Features_Code+42↑j
                              code:00008656 C3                       clr     C               ; Clear Operand (0)
                              code:00008657 E5 53                    mov     A, ZWOUT        ; Move (Op1 <- Op2)
                              code:00008659 95 58                    subb    A, SW           ; Subtract Second Operand from Acc with Borrow
                              code:0000865B D0 83                    pop     DPH             ; Data Pointer, High Byte
                              code:0000865D D0 82                    pop     DPL             ; Data Pointer, Low Byte
                              code:0000865F 22                       ret                     ; Return from subroutine
                              code:0000865F          ; End of function Motorsport_Features_Code
                              The added part of the launch control routine
                              Code:
                              code:0000866C          ; ---------------------------------------------------------------------------
                              code:0000866C          ; START OF FUNCTION CHUNK FOR Motorsport_Features_Code
                              code:0000866C
                              code:0000866C          LC_Ign_Cut_RPM:                         ; CODE XREF: Motorsport_Features_Code+12↑j
                              code:0000866C 75 F0 B4                 mov     B, #0xB4        ; Launch control IGN cut RPM
                              code:0000866F E5 3A                    mov     A, RAM_RPM_1    ; Move (Op1 <- Op2)
                              code:00008671 B5 F0 00                 cjne    A, B, code_8674 ; B-Register
                              code:00008674
                              code:00008674          code_8674:                              ; CODE XREF: Motorsport_Features_Code+61↑j
                              code:00008674 50 CB                    jnc     NLS_Limiter_Crank_Angle ; Jump if Carry is clear
                              code:00008676 80 AC                    sjmp    code_8624       ; Short jump
                              code:00008676          ; END OF FUNCTION CHUNK FOR Motorsport_Features_Code
                              code:00008676          ; ---------------------------------------------------------------------------
