Exchange of experience setting m.2.3.2 for beginners.
  • filip.krticka
    • Sep 2008
    • 170
    • Home: Czech Republic
    #46
    Hi, looking for an advice - why I need pull by timing so much incomaprison to original ignition map, arround the turbo spool up. Ingnition map P/T Load 110, 140 I have 7.5degree now (original software 14 degree MAF based software was runing almost fine).
    Dwell 3ms,
    AFR 12.
    What could by the source of my knocking issue?
    Is it down to VE map, I need to spent more time on Load 110 and 140???
    Any advice is welcome.
    • Acki
      • Mar 2014
      • 302
      I'm not able to check the logfile somehow - could you share some screenshots?
      • filip.krticka
        • Sep 2008
        • 170
        #48
        Dear Acki, thank you.
        Please find the log file in csv format attached.
        Current setup: K26/27 10# (Custom made by Vidar)
        Injectors Bosch EV14 613ccm 0280158123 -(710ccm 4bar)
        EFI fuel pump 400l/h
        red coils conversion
        Wagner exhaust manifold
        3" full exhaust
        standard inlet and exhaust camshaft
        engine is fully forged
        + Wagner IC
        1st note: I have not been working on N75 map yet.
        Exhaust temperature mesured after the turbo is 800°C max.
        Having lamba control switch off I do follow requested AFR. Under the full boost currently running richer 11,6.
        I have a variation but it's not lean it is always on the rich end max 0,4
        I made an assumption (maybe incorrect) it is not a big issue.
        2nd note>
        I have been running setup using K26/26/29 software with RS2 injectors on 5 bars, but I was not facing with knocking issue.
        I can share bin files with you as well. That is why I believe it is not hardware related.
        3rd note - data log sometimes crash ... it not an issue and it has been discussed in the different thread.
        Thank you
        • filip.krticka
          • Sep 2008
          • 170
          #49
          I have done a few analysis with excel speed sheet and found inconsistency within VE table I believe.
          Fix it and need to validate it by road testing.
          Hoping I’m on right track.
          • -ice-
            • Oct 2011
            • 173
            Hi,
            you have interessting label „knock retard deg“. Is this live ignition retard when knocking?
            BR,
            Dnuel
            • jonn48
              • Mar 2014
              • 92
              • Country: Russian Federation
              #51
              How to change the wall film enrichment parameters so that enrichment does not occur when the accelerator is released?
              • prj
                • Mar 2010
                • 6308
                There is no enrichment when pedal is released. Enrichment is done based on delta TPS, and negative = 0.
                • jonn48
                  • Mar 2014
                  • 92
                  #53
                  That is, the actual enrichment is due to the slow response of the MAP sensor? And one more question. In VEMS, wall film enrichment works without TPS delta, this is a percentage of the injection time difference. In motronics, is it different? And enrichment of the wall film only works with the TPS multiplier?
                  • prj
                    • Mar 2010
                    • 6308
                    It works as a TPS based enrichment in almost every ECU there is.
                    Please don't try to compare anything with VEMS, horrible ECU.
                    Of course MAP is slow. TPS is fastest, followed by MAF and only then MAP.
                    • jonn48
                      • Mar 2014
                      • 92
                      #55
                      Thank you Dmitry! Now I have to do Pnp VEMS for a friend, I also don’t like much in VEMS.
                      • prj
                        • Mar 2010
                        • 6308
                        I did the best I could for accel enrichment and SD. You understand, I had to code a whole new different algorithm in assembler, and do that within the confines of the stock ECU, which is also heavily processing power limited. It was not an easy task.
                        These days I just put Ecumaster on these
                        • jonn48
                          • Mar 2014
                          • 92
                          #57
                          If Ecumaster were to be installed right away, there would be “one of ...” And thanks to Motronic, all of Europe knows you)) Well, many grateful people for your work exist in the world.
                          • d_anev
                            • Dec 2013
                            • 48
                            • Country: Bulgaria
                            #58
                            ...all of Europe knows you)) Well, many grateful people for your work exist in the world.
                            Thumps Up !!!!!!!!!!
                            • jonn48
                              • Mar 2014
                              • 92
                              #59
                              Guys who use map switching? I tried to apply 12V to 46 pins and did not see the switch.
                              • asm-goth
                                • Jan 2020
                                • 7
                                • Country: Ukraine
                                #60
                                I tried to switch the maps and turn on and off the boost limitation, but after installing the patches, the boost is limited and when 6v or more is supplied, well, the specified contact does not happen, the boost is limited and the fuel card does not switch! Who got the switch?
