Hi guys I recently purchased a S2 (ABY) which was tuned by PRJ – has RS2 turbo, 440cc injectors etc and made 350hp 490nm peak boost 1.8 bar with perfect lambda.
Anyway I’ve been collecting parts and wanting to push things further with some flavour of a EFR.
Yes I know going aftermarket would be easier route etc but I wanted to give tuning the stock ECU an attempt.
My first issue is getting logging to work but Im not getting any data stream - I’ve read the wiki and done the following:
Can connect to the ecu after doing a WOT with my USB Hex 2 vcds cable just to prove the wiring is good:
By passed the stock IMMO box and joined the two green wires, The immo box is still plugged in but the two green wires are no longer going to the unit
I’ve installed WInlog on a Win7 machine 64bit and got the WinlogM232FastDiag.dll and then configured the comm port to match between device manager and WinLog,however I get no data stream.
Cables I’ve used are VAG KKL:
Then tried a BMW INPA K+D-CAN cable:
Here is a short video maybe someone can spot my error:
Additional information is I’ve tried on a second laptop with win10 64bit but again the same issue
Bobby
Bobby
