New dash speakers
  • Jamesey
    • Aug 2021
    • 154
    New dash speakers
    Fitted these today , sound so much better ,, what size are in the rear panels please
  • jp_paul
    • Aug 2010
    • 92
    I did the same on mine many moons ago, likely using the same pioneers that you've gone for. According to my Amazon invoice from 2011, I used Pioneer TS-G1313i 13cm 3-Way Speaker and 140W Max for the rear (and used Pioneer TS-G1013i 10cm 3-Way Speaker and 130W Max on the front). They fitted like a glove
    • Jamesey
      • Aug 2021
      • 154
      Yes they fit perfectly and sound tons better
      I've yet to look how to get into the back speakers in the rear side panels ,, any idea mate
      • Bowie69
        • Nov 2013
        • 2680
        Remove rear seat bolsters, and seat base, then there's a couple of screws holding the panel in, remove and pull it up like a door card.
          IIRC
          You’ll need a long socket to undo the seat back latching pin, or it’s an allen key and a ring spanner?
          Take a pic or count the threads to get them back in the same position.
          • Bowie69
            • Nov 2013
            • 2680
            Originally posted by newsh
            IIRC
            Yep, or I have some nicely cranked, old school, ring spanners for this job, 17mm from memory? Even some deep sockets are no good, as they haven't got enough clearance deeper into the socket.
              What model are these James?
              • jp_paul
                • Aug 2010
                • 92
                On the rear seat pins: they can be removed and refitted with a deep 17mm. If, as mentioned, you can't reach enough of the nut with the socket, you need to adjust the length of the pin using the allen key in the middle. If you can get away without adjusting them, they go on and off dead easy, lining then up with the seat socket when refitting.
                The card has a screw up near the quarter shelf, one behind the bolster, one in the kick plate and one you can see on the b pillar when the door is open.
                Don't forget to check your rear quarter shelf tweeters are wired and working before you refit the card!
                • Jamesey
                  • Aug 2021
                  • 154
                  Hi they are pioneer TS-G400. Cost me a tenner with a voucher .
                  £20 altogether but good price and worth it
                    • Dec 2017
                    • 6006
                    Just ordered a pair
                    • Jamesey
                      • Aug 2021
                      • 154
                      Originally posted by Tractor Dave
                      Just ordered a pair
                      They fit perfectly and very good priced .
                      just bend the spare 2 lugs up and over
                      • M_GORDON
                        • Oct 2008
                        • 1295
                        • Home: Isle of Man Current: Vatican City State
                        Pioneer?
                        Install some good alpine with silk tweeters Not much that 40€ and very good quality sound
                        Some spg or sps and can work amplified
                        photobucket SUCKS
