My radio signal is rubbish
  • My radio signal is rubbish
    I've lost my radio signal all of a sudden...it was fine 2 weeks ago but all of a sudden stopped ...the aerial is pushed in OK at the back of the set .
    Is the aerial powered on these cars
    Also have the same issue, it's another job on my to do list.
      Yes the aerial is powered, switched on by the radio. They do go wrong when water gets in. Or sometimes after a thunderstorm.
      You can access the aerial base by removing the rear dome light to measure if it’s getting power. There’s a small spade connector on a white wire?
      I need to change the one in my RS4, I can only get a couple of really strong stations, radio 2 and 4 here at home I think. Pretty sure it was lightning that got that one, we live on a bit of a hill with some real big trees around.
        Do you know which wire powers it because I've been messing with my wires to get a ignition feed
          Does your car still have its ISO connectors?
          A5 goes live when radio is switched on. I *think* it’s a white wire in the car but not sure.
            Thanks mate .
            Mines only got 4 wires on the live iso plug ...1 permanent live , earth , white wire and a very thin brown
              out of that lot you'll have blue/white for speed signal, blue/red for 12v, grey/blue for illumination, white for antenna, brown for earth
              Mike
              http://www.s2-audi.co.uk
                I'll get some shots later , definitely no ignition feed.
                  You'll want antenna, funnily enough.
                    Audi have never had an ignition feed to the radio on these cars. It's battery 12v only via fuse 4.
                    Mike
                      That’s correct. There’s a thin red on the back of the ignition switch that’s stays on till you pull the key.
                      Anyway, take the switched power out from the radio and connect it to the white to power the aerial
                        Thanks mate .
                        To get the radio to work with the 4 wire ISO you have to connect both constant and switched from the radio to the 12v on the ISO
                        Or if the radio is ISO then bridge A4 and A7
                          I replaced the amplified base on mine years ago and the radio reception was still rubbish.
                          91 Modded 3B
                          14 A6 Avant Black Edition
                            Me too
                            • #15
                              Stuck a merc sprinter item on mine, better, but not great still.
