RS2 roof mounted aerial angle
    My Avant has the 60 deg one I think, the spare is a 45 though.
    • johne
      • Apr 2007
      • 1406
      Originally posted by s2driveruk
      anyone got a partnumber, rough cost and source this side of the pond? I believe mine may well be leaking again arrrrrrrrrrrrg
      cheers
      David
      A smear of black silicon either side of the plastic gasket before screwing the mount down could be a better and cheaper solution.
      John
        cheers
        David
        Would be glad to know of a part number and supplier also, for a 45 degree Avant ?
        Ariel and base.
        Thanks.
        • s2driveruk
          • 12696
          yeah my vauxhall oem base gasket has leaked again...grrrrrrrrr was £13 rather than audi's £68 but not the right angle so need the coupe one and one which will actually last
          1992 3b S2 Coupe
          • johne
            • Apr 2007
            • 1406
            Try www.bluespot.co.uk
            they may be able to help you.
            John
            • saltinot
              • May 2004
              • 1946
              #21
              This is what I have. I couldn't find the number for the 60˚ base a la avant, but the coupe number (45˚) is below. I was able to find the mast and base (45˚) together as a kit.
              1H0 051 503 B antenna kit complete 45˚
              4A9 051 503 coupe base 45˚
              3A0 051 849 mast
              I have a couple of 60˚ bases in fine shape. If anyone needs one give me a shout.
                #22
                John and Tom,
                Thanks for your replies.
                Kind regards.
                • saltinot
                  • May 2004
                  • 1946
                  #23
                  You're welcome David. Let me know if you need any more info. I can source some things here if necessary.
                  • Tzummie
                    • Mar 2011
                    • 116
                    RS2 original roof antenna
                    Does anybody know if the 45-degree roof antennas are still available? I can only find the "16V" antennas in 60-degree angle. .. Fuba is not available in Europe, don;t even know if the Flex-D is still made..?
                    thnx
                    T.
