actually i wanna do concert ii stereo and i need illumination.
Help with audi concert
i thought you were trying to sell your car varia? haha
i actually was researching on how to connect the concertII up as well, from what i can read it looks like a need a trim piece from a 2000 cabriolet and fit that into our dash, and then with one of the adapters from teh links posted above it'll all work... anyone confirm?2011 black VW Touareg TDI - Daily/hauler
1991 black CQ- rally poser
1990 titan CQ- rombotis brunhilde racecor
1986 black Yamaha Fazer FZX - cafe bike projectComment
I have 2 cq, i will sell/part out the black one and keep the silver.
this one will work with my 1990 CQ
however, i wont spend $150+ just to get illumination. I dont care the speed volume control nor 1 hour auto shut off.
Second generation of concert 2 made by panasonic and here is the service manual
all i need is to find out which pin is the "illumination"
for old concert ii: http://www.audiworld.com/tech/elec86.shtmlsigpicComment
Concert I. works fine without adapter (simulator).
Concert II works fine, it has back ground light, but no illumination for the buttons.
You can fix it if you have the first generation concert II by grundig
(http://www.audiworld.com/tech/elec86.shtml)
You need a Audi Can Bus Simulator Concert 2 Chorus 2 Symphony 2 A4
(sellers name is: kunset*de on ebay, EUR 47.00) if you have the later version by panasonic.sigpicComment
Update on Concert Fitting
Managed to get time to carry out the Concert Upgrade. This really easy to do !
Attached FilesComment
Sorry about that been busy and had 2 look threw 4x 1TB drives to find it maybe it will help someone in the future.Attached FilesComment
I've a concert label says Concert M4, 4B0 035 186 C. Pin out for illumination is different to Concert mentioned here. Anyone know which pin to solder for illumination on this model ? http://www.audiworld.com/tech/elec86.shtmlComment
Sorry to bump such and old thread, but does anyone know if there added Concert outputs the station info to the autocheck like the Gamma CC radios used to?1990 Audi Coupe - 7A for nowComment
The 3 wires are there on the old connector(at least in the B3/B4 cars). Someone just needs to try to connect them to the new mini connectors, specifically the option one. I am just curious if the Concert I(or Delta CC since it was offered in the B4 chasis) can communicate with the older display standard like a Gamma CC can. I would like to keep the functionality if possible when upgrading my radio, but if I am unable to I will just get a Concert II(I know this won't work since it uses Can-BUS).
I went ahead and ordered a Delta CC off ebay with a narrower faceplate to try this with.1990 Audi Coupe - 7A for nowComment
