A friend of mine has found a supplier for din size PC's that will fit direct into the radio slot (double din also available)
12V
1ghz processor, choice of 256 or 512mb ram, 20, 30, 40, 60 or 80GB hard drive, slot loading cd or slot loading dvd-cd/rw
Front Access:
2 USB (V2.0), 1 Firewire and 2 Audio ports in & out
Just need to put a touchscreen screen in your car which cost around 150 and away ya go!!
Yup that is the same computer case i use. You can get it pretty cheap from www.cartft.com (german site). The computer case uses a via mpia mini itx board, then u have to get slim line ddr ram and a slim line DVD drive...
the casings is made by Casetronic and is called Travla C134. And it has been on the market for a while.
Another interesting link www.mini-box.com they also sell a 12 V drop out regulator, which is very usefull and has a 8 amp fuse.
12V
Front Access:
Is there anyone who supplies these in th UK??
Mark
Race Clio RS197
S2 Coupe ABY (Green) - RIP
S2 Coupe ABY (Blue) - Sold
I'll see what i can find out thru my mate that found them.
www.mini-itx.com has everything that you need and they have the travle C134 case. You have to buy motherboard (cpu included), ram, HD, Cd drive seperat. But they should have it all on www.mini-itx.com
Looks awesome, first off i was thinking "who's that idiot who removed the climate control "
But when seeing all the pics it really comes togheter
So, when will you come by and fix my car like that
Well Niels,
I'll come by when that nice girlfriends of yours makes some nice leather doorsides for me?
If you want i can help you mount in car pc, no problem. But i think i leave you up to fitting the 7" screen. Cuz that to forever of sanding and then put some more "plastic padding" (not sure about the spelling) on to make the screen look stock.
However iam going to remove the carbon look and paint the hole console minus the heater valves in some kinda plastic black color.
Right now me and Kenneth are making the final touch on my new doorsides, so i can have 2x 6½" speaker in each door.
more pictures to come.
SKI:
Thanks alot, took me quite some time in the garage, but i quite like the result.
Wireless and Networking Experts. UK based distributor of MikroTik RouterBoards, Ubiquiti Master Distributor including Unifi and airMax. Supplier of routers, firewalls. IT and Networking consultancy.
to name but 2, there are others but these are the 2 i have been using
Ant
2011 Kawasaki Z1000
Sound card im using has 6 channel outs, 3.5mm jack split in to phono leads and that will feed the amp fine for sound and software on the PC can be used to refine frequency and balance etc.
Im interested to know what the voltage of the outputs are tho as i cant find any info on this one, so how it will actually sound will be a mystery until its fitted
No headunit will be used tho. I have a WinTV USB thing for Radio and TV.
Ant
2011 Kawasaki Z1000
