ICE wiring
This is a sticky topic.
  • GlynRS2
    • Dec 2003
    • 307
    Peter,
    In that your RS2 has the original wires to your ISO connectors I wondered if you could tell me which coloured wire is the illumination one, going to pin 6?
    The wiring on my RS2 has been butchered in the past when someone stole the radio about 5yrs ago. According to the paperwork I have it was then rewired by Scotts Audi when the fitted the head unit that was in the car when I purchased it. Although they refitted the correct ISO connectors, they did not fit the illumination wire, so I wondered which colour wire it was from the original loom? Looking at it I am surpised how thin the wires in the original loom are and can see why some people take a power supply back to the fusebox if they are into ICE. In the original loom wiring the wires are red (permanant 12V), brown (battery -ve), white (control +ve for aerial) and then there is a grey and blue wire which I guess is illumination, but could you confirm that please, or tell me otherwise.
    In fact the wiring repair that was done by Scotts is generally pretty poor, so I am planning to redo it all anyway. Interestingly they had spliced a wire to connect pin 7 (battery +ve) to pin 4 which overcomes the problems that you were experiencing. At least it does work!
    I have been toying with the idea of fitting an Audi Chorus 2 headunit, but that requires the use of an amp as it only has pre-outs for the rear speakers. Also I would have to adjust the unit slightly - it is 22cm wide, where as the maximum width of the centre console is 21cm
    Anyway the original RS2 wiring should go something like this:
    What I want to acheive is the factory fit look and I picked up the Audi head unit off my brother for nothing who upgraded the system in his wife's A2. My other option is to fit a VW Gamma unit which I also have knocking around the garage, this has nice red illumination on all the buttons, with just the display being blue.
    The connections for the Gamma unit on connector III is pin 1 Gala (speed sensor), pin 2 MUTE, pin 3 K-Bus (to ECU to remember code when battery disconnected), pin 4 switched positive, pin 5 control +ve for aerial, pin 6 illumination, pin 7 battery +ve, pin 8 battery -ve.
    Glyn
    Ex-Polar Silver RS2
    Sprint Blue RS4 - new toy :mischeif:
    • Pete_RS2
      • 800
      Glyn,
      Yes the grey wire with blue trace is for illumination dimming.
      Now RS2'less
      '99 VW Passat VR5 Sport
        • 12431
        Im gonna get the wiring out on my stereo again tomorrow because the radio reception has always been crap and i think it may be down to this wiring. Ive just had a read through this thread and at present I have the brown connector for 4 speakers and black connector with pins 5,6,7,8 connected. Will check the colours tomorrow. Also there is a seperate cable with a brown connector, what is that for?
        • Sonic
          • Jul 2006
          • 5514
          Did you ever find this out?
          Im having the same confusion now trying to get mine all connected up!
          S2Forum.com Administrator
            • 12431
            I must admit, I didnt get it sorted before and its been one of those jobs ive not got round to doing.
            • Sonic
              • Jul 2006
              • 5514
              #21
              Im assuming
              pin 5 - antenna
              pin 6 - illumination
              pin 7 - battery +ve (meant to be switched +ve for ISO)
              pin 8 - ground
              So the seperate brown connector could be the switched +ve that the stock connector is missing.
                #22
                Have a swatch at --->
                or
                or
                  #23
                  None of which call out a brown connector. But I see T8b or T8c might be it. Looks common to all options...
                    #24
                    Its T8b
                    1 = white / blue for vehicle speed (GALA)
                    2 =
                    3 =
                    4 =
                    5 = white to aerial, buzzer and/or autocheck - pretty sure its 12V output from radio to power aerial amp and this activates alarm when key removed
                    6 = grey/blue for illumination (via E20 rheostat)
                    7 = red/blue for permanent 12V input via Fuse 4
                    8 = brown for 0V ground
                    • Sonic
                      • Jul 2006
                      • 5514
                      #25
                      You *******
                      Ive just spent the last half an hour working that out.
                      Looks bang on - its a black 8 pin connector i have with pins 5-8 connected, no speed sensor at pin 1 though - this could be the additional plug that i have. Ill look at the wire colours to determine tomorrow.
                        • 12431
                        Andy, id be interested to see how you get on. I have a long list of little bits to sort on mine so if its an easy fix I will have a look at it sometime in the near future
                        • Sonic
                          • Jul 2006
                          • 5514
                          #27
                          Ive got most of it connected up already, just need to run a seperate switchable +ve from somewhere.
                          Will get some photos
                            • 12431
                            Just been changing the head unit on mine again and checked the wiring colours. The odd cable on its own is Brown/Grey with a brown connector also. Been trying to find the black aerial amp lead too but to no avail and with the weather the way it is today i didnt want to have the door open in the rain really, so may buy a new aerial with the power integrated into the coax lead since I already have an adaptor for it. Any suggestions on which aerial bases are suitable?
                            • Phil Payne
                              • Jul 2009
                              • 328
                              Gives you the pin out for the ISO connector, some ideas for the feeds and the part number for the extra pin from Audi.
                              • Evilgoat76
                                • Feb 2010
                                • 278
                                • Home: Canada Current: United Kingdom
                                #30
                                For you guys after redoing the wiring. I have used the screw on ones on many installs to clean up botched wiring ....
                                CPC Farnell ISO Screw term plugs
