What tech have you added inside you S2/RS2?
    I will send you one with wiring tails fitted so you can splice in and try that app and adapter combination.
    I have a bunch of them from an old / forgotten project that I will probably sell at cost on here to anyone interested.
    • urS6Tom
      • 773
      That'd be great - have PM'd you my address.
      • dhali7376
        • Nov 2009
        • 301
        I would be interested in one .
          Ok - I will start a separate thread on that.
            I'm fitting an OBD port on mine and I was curious what happens to the L-wire which I believe is not used?
              #21
              Not all controllers use the L-wire but if the vehicle has both then just wire them both up.
                Thanks Paul, so connect the L & K wires together at the OBD connector?
                In order to hook up the OBD I have taken 12v, earth from the black T2 connector and K & L from the eyelet posts at the fuse board position into a mini harness which will terminate in the OBD plug
                  #23
                  No no - there are separate pins on the ISO plug for K and L. I need to take a pic or find a link.
                    #24
                    Pin 07 is K
                    Pin 15 is L
                      I was going to do this a while back and bought a cheap 2 x 2 adapter to cannibalise, but it was a bit short (and cheap) and I never finished the project.. If there's a spare connector going I'd be happy to pay for one Paul.
                        #26
                        No probs - let me find the box with the bits and pieces - think I have 10 or so - hopefully with enough pins to go round.
                        • rj scotty
                          • May 2006
                          • 2195
                          #27
                          ill give you beer vouchers for one, 2+2 under the bonnet is a pain in the ***
                          BUT I DON'T WANT A NEW CAR!
                          1995 S2 Avant, Volcano Black
                          • Thuppu
                            • 4115
