Knocking and banging and general bad vibes.
  • BRY
    • 3755
    Top mount specialists ?
    • alg
      • Apr 2004
      • 1160
      Originally posted by Jas11n
      I was asking last week within the propshaft refurb thread about possible vibrations and noises on my car.
      Thought I'd best not messs that thread up as the end diagnosis wasn't the prop.
      If you experiance really bad vibrations and noises at low revs/idle, on the overrun, under load in a high gear and rounding corners, then please make sure sure your engine mounts are fine.
      Mine are, but the engine mount support that bolts to the block on the offside has no freakin bolts in it None there at all, all dropped out and lying on some unknown road.
      Engine on the offside is now sitting nicely on the damn subframe.
      Easy enough fix, but then they should have been tightened properly first time round.
      I'm mad as a hatter (and not mad as in "crazy", but mad as in I'm going to "kill someone")
      Jas
      Really sorry to hear this m8. I was just admiring your recently posted pics too. Must admit I never fitted my topmounts (concerned re longterm roaduse).
      Alastair
      RS2
      • T2Andy
        • 1903
        Bry is that why you wanted to remove my stickers? By the way the RS2 grill is on
        complete with black rings ,does look good cheers again for that
        Its a mazing how people can go from hero to zero overnight.
        • Fat Audi 80
          • 10547
          lost me there Steve
          Don't worry I was absolutely miles away... Ignore that one!
          The Perfectionist
          • cochyn92
            • 38
            • Home: Wales Current: Fujairah
            #20
            Blimey jas, that sounds like Quite Risky S***!
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              #21
              PSML.....now that was a good clue
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
              • S2 Ant
                • 3682
                Originally posted by Jamo
                Can't say really mate, but it's not hard to work out.
                When someone does **** work on a car, then i think someone can say!!!
                Clearly opinions thru experience are showing just how **** this place is when it comes to workmanship....
                Im a lil confused by the fact you had to pay for these repairs Jas when clearly they must have ****ed up???
                Ant
                2011 Kawasaki Z1000
                • BRY
                  • 3755
                  #23
                  Knowing it and proving it are two different things, though ANT.
                  Pay them and then slate them till they are no more.
                  • Jas11n
                    • 5067
                    They will pay Ant, one way or another
                    2001 Avus Silver B5 RS4.
                    1995 S2 Coupe - sold (sniff)
                      Jas11n who checked over your car to find this lot out?
                      • Jas11n
                        • 5067
                        My local "good guy" specialists based about 6 miles away from me. Based in Medowfield, Durham. They know the S2 inside and out as Stuart (chief mechanic) used to have two of them. Mak2503 has used them, Lune (Ben) uses them and even Mark has had a service off them.
                        Only reason they didn't get the car to fix in the first place was because they didn't do bodywork.
                        You live and learn.
                          Ah shame, too far away, i've got a major banging noise, when i brake at any speed and i can feel a thud by my feet next to the transmission tunnel.
                          It's driving me crazy
                          • s2driveruk
                            • 12696
                            mate thats you wishbone bushes!!!
                            1992 3b S2 Coupe
                            • s2driveruk
                              • 12696
                              i had that about 18 months ago and was driving me mad, convinced it was aheat shield or something else close to my feet but when i jacked the car up, nothing obvious, then when i looked about the suspension for any signs of movement the metal sleeve inside the rubber bush had parted company, allowit to move on the retaining bolt...probably sounds worse in the wet too?
                              edited...here's a pic:
                              1992 3b S2 Coupe
                              • Jas11n
                                • 5067
                                What about taking it to where Ben (s2avant) gets his work done? Is it Lions Garage or something along those lines? Really need it up the air to get a good look.
                                Jas
